shudder when engaging reverse or drive. what is wrong?
lcgtr1970
, Oct 14 2011 07:37 AM
10 replies to this topic
Posted 14 October 2011 - 07:37 AM
Hi guys.
Sometimes when I select either reverse or drive in the ute it shudders . This doesn't happen everytime I do it, and there seems to be no real pattern either just randomly does it. The combo is 308, trimatic and it has a 6 cyl diff. A few months ago the rear uni on the tailshaft went which I replaced so it should be fine, and there doesn't seem to be any vibration from the shaft so they should still be good.
Is it the box?
Anyway any help will be appreciated. Thanks
Is it the box?
Posted 14 October 2011 - 08:38 AM
sounds like the box to me
Posted 14 October 2011 - 11:55 AM
Engine mount.
_CHOPPER_
Posted 14 October 2011 - 04:08 PM
Unlikely to be in the box, unless it's low on fluid. Check the engine and trans mounts first. And that the bolts are tight.
Posted 14 October 2011 - 08:31 PM
Checked box fluid and all is good. Box shifts well normally and when given a hiding. I'll check the engine mounts and see how they look. Anything in particular I should be seeing...apart from cracks etc?
Posted 14 October 2011 - 10:33 PM
^^^ +1
Most likely cause of shudder is worn clutches.
Could also be low line pressures or leakage past the detent valve but that would create more like a take off bump rather than a shudder.
Posted 14 October 2011 - 11:40 PM
If it's worse cold, I'd say servo seals.
_wombat_
Posted 14 October 2011 - 11:41 PM
i had same thing years ago in my 308/trimatic vk,took it back
to pete at welspool autos and he said straight up it was "govener"
on output shaft(in extension housing) changed it and no trouble
for 15 years
for 15 years
Posted 17 October 2011 - 06:19 AM
Was it an expensive fix wombat?
_wombat_
Posted 17 October 2011 - 07:10 AM
was warrenty mate,could'nt see it being that much,dont have to pull box
to do it.
to do it.
