LH Radio
28 replies to this topic
#1 hanra
  • 11,020 posts
Posted 15 November 2011 - 03:18 PM
Does this look like the correct radio for an LH?
If not, what is?
#2 _LH SLR 3300_
_LH SLR 3300_
Posted 15 November 2011 - 03:36 PM
Yes, i believe so, it looks like an LH factory option Air Chief. I have three of these, two 13 transistor & an 11 transistor. The speaker wires join into a single plug that goes into the back of the radio, i've been advised if the radio is in working order & you wish to keep it so, do not switch the radio on unless the speaker is connected.
#3 ReplicarSLR
ReplicarSLR
  • 518 posts
  • Car:Not anymore unfortunately
Posted 15 November 2011 - 04:20 PM
The knobs are correct for Torana, but the radio is not LH as the face looks bigger (hight wise, face should only be as thick as the radio body) and it appears to be missing the push buttons.
#4 _LH SLR 3300_
_LH SLR 3300_
Posted 15 November 2011 - 04:55 PM
I noticed the absence of the push buttons to, i do know from an original LH Torana P&A brochure i have that there were three Air Chief radio options, an 8, 11 & 13 transistor. Also, here is a pic of my 1974 LH which has it's original factory fitted Air Chief, it looks very similar to your's.
Here is a pic of the one i plan to fit to my SL/R including a rear shot showing the dual wire/single speaker plug.
I wonder if your's is an 8 transistor as i've never actualy seen one, or maybe it is from another car but with Torana controls fitted to it. Have you trial fitted it to your car to see if it fits?
#5 _fatlh5000_
_fatlh5000_
Posted 15 November 2011 - 07:45 PM
Brad,
The radio you show has numbers 5,7,8,10,12,14,16
The other radio is 5,6,8,10,12,14, and it has psuh buttons.
I believe the radio you show is incorrect. The Radio Matt shows is correct.
You definitely need a CHIEF in your dash Brad. Just make sure your das wears the right Cheif !!!!!!!!!!
Edited by fatlh5000, 15 November 2011 - 07:46 PM.
#6 hanra
  • 11,020 posts
Posted 15 November 2011 - 10:16 PM
WOW thanks for all your help guys! I dont actually own that radio, I was going to bid on it on eBay. But thanks to your wealth of knowledge, Ill hold off until the right one comes along!!!!
Thanks again you guys!!!
#7 hanra
  • 11,020 posts
Posted 15 November 2011 - 11:04 PM
This one says its Air Chief and looks a lot like the above pics, but the sticker on it says Philips??? Did Philips take over Air Chief back in the day?
http://www.ebay.com....=item3cbe36ee13
#8 _toranarama_
_toranarama_
Posted 15 November 2011 - 11:14 PM
Stick in a Celica one, nobody will know the difference ! :P ;)
#9 _Quagmire_
_Quagmire_
Posted 15 November 2011 - 11:42 PM
ebay listings only go back 60 days....but if you bear with me i will see if i can track down the photos of my old one
#10 hanra
  • 11,020 posts
Posted 16 November 2011 - 01:04 PM
That would be great!!!
#11 Dr Terry
Dr Terry
  • 3,329 posts
Posted 16 November 2011 - 02:31 PM
I believe those two radios are correct for both LH & HJ series Holdens. The only difference is the knobs , the Torana ones are pictured. The first one is the basic 'manual' version & the second one is the Deluxe push-button version. I think the manual one had 8 transistors & the push-button had either 11 or 13.
Strictly speaking Air Chief is not a manufacturer of car radios, it's just the name that GM-H applied to radios that they authorised as being factory accessories. The original manufacturer of Air Chief car radios was REI, which became Astor sometime in the 60s & was in turn bought out by Phillips in the early 70s.
Dr Terry
#12 S pack
  • 15,745 posts
Posted 16 November 2011 - 05:11 PM
Dr Terry
Just like the LJ & HQ radios, the LH Air Chief radio was available in 4 different models:-
8 Transistor - manual tuning only.
11 Transistor - manual tuning only.
11 Transistor - push button.
13 Transistor - push button.
As Dr. Terry said, the Air Chief and Air Ranger radios for our beloved Torana's (and 70's Holdens) were made by Phillips.
#13 hanra
  • 11,020 posts
Posted 16 November 2011 - 08:56 PM
Awesome info there Dave! Thats a great help indeed!
#14 _walpolla_
_walpolla_
Posted 17 November 2011 - 03:23 PM
This is on ebay at present.
http://www.ebay.com....=item27c044281b
regards,Rod
#15 hanra
  • 11,020 posts
Posted 18 November 2011 - 10:01 AM
That one looks a bit different?
#16 _fatlh5000_
_fatlh5000_
Posted 18 November 2011 - 10:18 AM
regards,Rod
That looks like a ford radio !!!
Far too UGLY for a Torana.
#17 _chrome yella_
_chrome yella_
Posted 18 November 2011 - 10:20 AM
that last ones wrong, the two pushbutton models , i think i have worked out. I have a pb air chief and the word air chief is in the centre of the fascia and doesnt have deluxe written after it, it still has the little logos on the ends thou, i guess that would be an 11 transistor type which is perfect for a L34 as theres no need to have the extra weight of 2transistors.
#18 hanra
  • 11,020 posts
Posted 13 August 2015 - 08:33 PM
Just noticed someone is repro'ing the radio knobs!!!!
http://pages.ebay.co...lobalID=EBAY-AU
#19 arrimar
arrimar
  • 3,134 posts
Posted 17 September 2020 - 07:06 AM
..and now the LH specific DAB am/fm bluetooth is available in both airchief 11 and 13, manual and pushbutton versions.
https://www.retrosou...t_detail&p=2988
https://m.facebook.c...969985869753873
Edited by arrimar, 17 September 2020 - 07:09 AM.
#20 Shiney005
  • 9,720 posts
Posted 18 September 2020 - 12:21 AM
Sweet.
#21 arrimar
arrimar
  • 3,134 posts
Posted 11 November 2020 - 11:15 AM
I've wanted this to fill the gap around the radio for a long long time.
Fits pefectly in the dash.
(Second decal is for another car, comes in Deluxe 11 or 13)
Replacement air chief metal decal for LH.
https://www.retrosou...t_detail&p=3003
Replacement air chief fascia for LH.
https://www.retrosou...t_detail&p=3183
#22 arrimar
arrimar
  • 3,134 posts
Posted 11 November 2020 - 11:43 AM
The shaft nuts are often missing if buying a second hand air chief.
They're not something you can buy easily so I had some made, if anyone wants a pair send a PM.
#23 Shiney005
  • 9,720 posts
Posted 01 October 2023 - 09:36 AM
Do you still have any of those shaft nuts for sale Arrimar?
If the LH radio only has the one headphone style speaker plug with two wires, how does it power the optional rear speakers?
Attached File  IMG_0602.jpg   44.01K   3 downloads
The HQ advertising below shows the exact aerial (including the grey lead) that I have just removed from my L34, so they were still in service for LH Torana.
Attached File  376410561_3534883093499448_6587947010700137841_n.jpg   196.13K   5 downloads
#24 hanra
  • 11,020 posts
Posted 01 October 2023 - 08:57 PM
Any help here?
#25 Shiney005
  • 9,720 posts
Posted 02 October 2023 - 10:32 AM
Nah. It was more the rear speaker wires I was wondering about.
