Wheels studs(2) broke and wheel come off.
#1 _gallego_
Posted 20 November 2011 - 08:32 PM
#2 _CHOPPER_
Posted 20 November 2011 - 08:41 PM
#3 _toranarama_
Posted 20 November 2011 - 08:56 PM
Bathurst XU-1s did on the front (trivia)
#4 _gallego_
Posted 20 November 2011 - 09:00 PM
#5 _CHOPPER_
Posted 20 November 2011 - 09:02 PM
But as a 9" conversion is listed, it doesn't appear to me spacers were used.
#6 _toranarama_
Posted 20 November 2011 - 09:04 PM
#7 _CHOPPER_
Posted 20 November 2011 - 09:09 PM
#8 _gallego_
Posted 20 November 2011 - 09:12 PM
#9 _Bomber Watson_
Posted 20 November 2011 - 09:23 PM
Work out what size you need and browse Summit.
Posted 20 November 2011 - 09:27 PM
Driving along a side street doing 60 km/h my rear passenger wheels decide to off.It broke 2 studs and wheel went flying down the road and hit a car.No one thats the main thing...Where can i get some sronger wheel studs? Im running a 9" mini spool 4.11 31 spline.not much damage to the torana only the flair guard and brake disc.
AFAIK over tightening of the wheel nuts can also cause the studs to sheer.
So 2 studs sheered off and the wheel parted company with the car.
If you don't mind me asking, what happened to the other 3 studs that should have kept the wheel on?
Edited by S pack, 20 November 2011 - 09:28 PM.
#11 _toranarama_
Posted 20 November 2011 - 09:29 PM
#12 _CHOPPER_
Posted 20 November 2011 - 09:36 PM
Correct.
Posted 20 November 2011 - 09:37 PM
We'ren't using Commodore wheels on a HQ pattern were we ?
Never ever let anyone tighten your wheels with a rattle gun either
#14 _toranarama_
Posted 20 November 2011 - 09:38 PM
Torque wrench or cross brace = GOOD !
#15 _gallego_
Posted 20 November 2011 - 09:49 PM
#16 _toranarama_
Posted 20 November 2011 - 09:51 PM
Sounds like some ones got it in for you...
(be afraid, be very afraid)
#17 _CHOPPER_
Posted 20 November 2011 - 09:57 PM
99.9% of retards at tyre shops use rattle guns to tighten wheels = BAD !
The retards use guns to break studs. I use guns to nip them up and then use a torque wrench. If a shop doesn't have at least two torque wrenches, go elsewhere.
And gallego, from what you have posted one of three things happened:
#1 Loose wheel nuts.
#2 Damaged rim and/or nuts.
#3 Incorrect wheel/ locating hub on axle too big.
Doesn't sound too 'well checked'
Posted 20 November 2011 - 10:15 PM
So you checked the wheel nuts... and 2 studs broke...and 3 nuts are missing
Most likely scenario, 3 wheel nuts came loose or were loosened (sabotaged) by some f#@wit, the 3 nuts came off completely and the remaining two studs with nuts still attached couldn't take the strain so they snapped off.
As Gordon said,
#20 _toranarama_
Posted 20 November 2011 - 10:24 PM
If all 5 were "loose" and uhh hmmm "checked" with the wheel on the ground it is "possible"
to think you've tightened them but the wheel was actually on an angle thus giving the impression the nuts were tight...
Still....
#21 _CHOPPER_
Posted 20 November 2011 - 10:26 PM
If he can put a 9" in his car, surely he can tighten wheel nuts properly.
#22 _toranarama_
Posted 20 November 2011 - 10:30 PM
apparently not
OR...
#23 _CHOPPER_
Posted 21 November 2011 - 08:11 AM
#24
Posted 21 November 2011 - 11:14 AM
I would still check the centre hubs of the 9" conversion, just to be sure. If the left hub wasn't turned down enough, thre's no way the wheel would be able to sit properly on the axle. This of course would allow the wheel to come loose.
My first thought also.
I'm seeing more of these so called 'professional' 9" conversions of late where the centrebore plays no part in securing the rim.
#25
Posted 21 November 2011 - 11:29 AM
I'm seeing more of these so called 'professional' 9" conversions of late where the centre bore plays no part in securing the rim.
That is because the axle locating hub is only there to help align the rim and in most cases the brake disc. It has to no part in securing the rim, once the bolts are tightened there will be a gap between the axle locating hub and the rim.
What Chopper is saying is to check that the centre bore in the rim is large enough to fix over the axle hub. If the hub is too large or the rim centre bore is too small this will prevent the rim sitting down on the axle when the wheel nuts are tightened. If this was the case then eventually the rim will work its way onto the axle leaving the nuts loose.
