LC GTR standard ride height
_1970lcgtr_
Posted 21 November 2011 - 10:31 AM
Was gtr height same as sl model?
I bought a new set of king springs in standard height as i wanted to keep the original look but after fitting the rears the arse end looks way too high?! Now im thinking of starting again with the 'lowered' units...(havnt fitted fronts yet)
Any info would be appreciated....
Posted 21 November 2011 - 10:48 AM
Standard 2"
GTR 1"
New springs can take a little time to settle.
Posted 22 November 2011 - 12:02 AM
Exterior Dimensions
Overall Heights - at kerb weight
82311, 82369, 82569 - 53.9 in.
82911 - 54.2 in.
Minimum running ground clearance
82311, 82369, 82569 - 5.8 in.
82911 - 6.1 in.
P.S. The above dimensions are probably going to mean diddlysquat if you are not running the same size tyres as the original factory fitment. To rework the dimensions you will need to know the rolling radius of the original fitment tyres and the rolling radius of your existing tyres and add or subtract the difference from the original dimensions.
_1970lcgtr_
Posted 22 November 2011 - 07:32 AM
Anybody have any info on the king springs, should i have bought 'lowered' springs to get standard gtr height? I wanted to retain the original look and not have it look like its dumped on its guts..
Anybody have pics of their car with 'lowered' kings fitted?
Posted 22 November 2011 - 11:06 AM
According to the Max Ellery book.
Rear Spring Specifications - LC & LJ Models
Free Height
Std 8.75"
GTR 7.39"
Working Height
Std 6.44 " @ 433 lbs.
GTR 5.66" @ 433 lbs.
Edited by ls2lxhatch, 22 November 2011 - 11:07 AM.
_1970lcgtr_
Posted 24 November 2011 - 05:47 PM
Kings dont list different springs for SL, GTR or XU1 models. Just LC/LJ 6cyl standard or lowered. Thinkin i better start over with the lowered units and hopefully get an exchange. Spewin!!!!
_CHOPPER_
Posted 24 November 2011 - 06:44 PM
From LC Torana advance service information (pre release of the LC Torana).
Exterior Dimensions
82911 - 54.2 in.
82911 - 6.1 in.
The original diameter of most LC/LJ 13" tyres was between 590 - 610mm.
