The 161 Red Motor Screeema
Starter motor issues
27 replies to this topic
#1 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Name:Jesus Bloody Christ
  • Car:Goon
Posted 04 December 2011 - 08:43 PM
Together with a research analysist from Dow Corning,I have been developing a new type of oil ring for the mighty red 6.
It is an O-ring type oil ring,with 29.5% silicon content.
To this point,results have been promising.
Bedding in issues have been virtually eliminated,as we are using simple beef tallow as a lubricant.
Smells like a chip shop when you first kick it in the guts,but by using E85 this issue is minimised.
The biggest problem encountered to this point has been overcoming the piss weak red6 starter motor iand its ability to crank the engine over.
It is my understanding that there is a Dellow adapter available for using a 253 starter motor as a solution.
Has anyone used this style of adapter to overcome this issue?
#2 _toranarama_
_toranarama_
Posted 04 December 2011 - 08:52 PM
Multiple cans of Woodstock + o rings
I can see where this is headed ! :driving:
#3 rodomo
  • 18,051 posts
Posted 04 December 2011 - 09:22 PM
Rocket science mate!...........................................Pure GENIUS! :spoton:
From memory, you can drill and tap a steel Holden/Landrover conversion plate and use that?
#4 TerrA LX
Posted 04 December 2011 - 09:43 PM
About time someone showed up on this forum with some enginuity, Hey Wot I've been looking into a control ring that will last in my 253 screemers, do you think your mate at Dow Corning would be interested in knocking up some of those o rings for a 308 piston to squeeze into a 253?
#5 TerrA LX
Posted 04 December 2011 - 09:46 PM
Anyone with any idea could see that this thread has Jenuinly Distinguished input.
#6 rodomo
  • 18,051 posts
Posted 04 December 2011 - 10:18 PM
Does the "O" ring roll in the groove as the piston goes up and down?
I wonder if square section "O" rings would be better? You know, like the ones on oil filters? :dontknow:
#7 _toranarama_
_toranarama_
Posted 04 December 2011 - 10:23 PM
There used to be an aftermarket Hi-Torque red 6 starter available, are you using one?
#8 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Car:Goon
Posted 04 December 2011 - 10:26 PM
I originally just pumped sikaflex into the oilring groove and dropped the piston into a wellgreased bore to let it set,creating a square edged o (square)ring as you suggest.
But it wouldnt rotate and oil kept sneaking past, washing petrol off the bore,so it was a fail.
Stick with the o-ring,mate,and you wont look back.
Geeze.....can you still buy them new? A genius suggestion I had never considered.(goes to look on ebay)...
#9 rodomo
  • 18,051 posts
Posted 04 December 2011 - 10:27 PM
Roller ring!.......................I like it!..........................Has a certain ring to it?
#10 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 04 December 2011 - 10:28 PM
Hi
I would go here before someone else gets in on the act
http://www.ipaustralia.gov.au/
Bazza
#11 rodomo
  • 18,051 posts
Posted 04 December 2011 - 11:17 PM
:lock: QUICK!
#12 _oldjohnno_
_oldjohnno_
Posted 05 December 2011 - 10:15 AM
All good with the special rings and the beef tallow (mmmm tallow...) but you goofed up on the Dellow adaptor.
The one you want doesn't use a 253 starter, it uses a 253 as the starter (hey, they've gotta be good for something). You may have to massage the inner guard and firewall slightly for clearance.
#13 _CHOPPER_
_CHOPPER_
Posted 05 December 2011 - 02:59 PM
To use a square section "O" ring rquires a square hole to be drilled using a square drill bit.
#14 _double_d_
_double_d_
Posted 05 December 2011 - 03:27 PM
shit i did this years ago to a mower , lol
when i was 18 the old fella next door seen me mucking around with an old mower i bought and gave me another the same
i built one out of the two
and when our lease was up we decided to move the old fella came over and asked for his mower back that never went mind you
i put it back together with an o ring in it hopeing it would last long enough till i was gone then burn away
never heard about it after that
lol , its probably still going
#15 TerrA LX
Posted 05 December 2011 - 05:18 PM
shit i did this years ago to a mower , lol...
Do you remember what lube you used to re assemble the motor with?
#16 _hutch_
_hutch_
Posted 05 December 2011 - 05:44 PM
as far as the starter goes all ya need to do is swap the nose cone from the 1.0 KW 6 cylinder starter onto the 1.6 KW v8 starter,and take off the rear mount,and bobs ya auntie
Phillip
#17 _Bomber Watson_
Posted 05 December 2011 - 05:54 PM
This would go well with a cylinder head design im working on...
Just a 12 port with no valves in it. I have put welsh plugs in the valve guides.
The "cam timing" will be controlled by pulse tuning, carefully designed lengh runners on the intake and exhaust to put the pulses in the exact correct timing to allow the engine to operate like normal.
Hardest thing to work out is how to get a starter motor to turn it to the 18000rpm required for this pulse tuning to take effect....
#18 micklx
micklx
  • 1,785 posts
Posted 05 December 2011 - 06:41 PM
Bomber, this engine without valves of yours, how much compression do you plan on having ?
#19 TerrA LX
Posted 05 December 2011 - 07:01 PM
Atmospheric...
#20 _oldjohnno_
_oldjohnno_
Posted 05 December 2011 - 07:14 PM
The funny thing is that fully functional engines have been used that employed nothing more than wave tuning for cylinder charging and scavenging. The piston did no pumping work whatsoever. They were used early last century to drive a generator, an application where their ability to run at only one speed was more of an advantage than a weakness. To start them they had to be motored up to speed and a blast of compressed air shot into the intake pipe.
I'm guessing the pipes would have been quite a bit longer than the ones on your 18k 202 though...
#21 rodomo
  • 18,051 posts
Posted 05 December 2011 - 07:19 PM
It's still got me buggered how these things work?
http://en.wikipedia....ve_supercharger
Probably cos I have a short attention span? (I was A.D.D. before it became fashionable)
I haven't read/thought it through.
Ex Mrs had one on an imported Mazda diesel and it went like stink.........................for a diesel.
#22 _oldjohnno_
_oldjohnno_
Posted 05 December 2011 - 07:55 PM
Think of a rotor shaped like the drum of a revolver or six-shooter, with end plates having round ports. Exhaust gas enters one end and compresses the air, jamming it up the opposite end of the chamber. At this point the port at that end opens, allowing the compressed air to be forced into the cylinder but the port closes just in time to prevent exhaust gas from carrying over into the cylinder. Pressure waves are able to pass freely through both the exhaust and the fresh charge, without much mingling of the actual particles.
Soon after this both ends are opened allowing the exhaust to well, exhaust, and pull in a fresh charge of air. Supercharging is possible because of the heat and energy of the exhaust gas being able to pull and push a volume of air greater than the cylinder capacity.
That's a simple explanation and the actual construction might be a bit different but I hope you get the idea.
#23 rodomo
  • 18,051 posts
Posted 05 December 2011 - 08:30 PM
Thanks Johnno.........................I actually had to read that 3 times to take it all in. :fool:
What happened with the Ex's was the belt broke, all hell broke loose, gasses were going where they weren't wanted/needed and nylon internal bits melted (bearing seals) smoked out the exhaust worse than Puffing Billy .........................................................$700 later and no warranty, a brand new second hand one was fitted and then the car was sold. :wacko:
Alt belt drove off the crank, the Alt had a through shaft that belt drove the microwave supercharger.
#24 _double_d_
_double_d_
Posted 06 December 2011 - 05:25 AM
bit of stp i think was 17 years ago but thats what i would of had on me
#25 _oldjohnno_
_oldjohnno_
Posted 06 December 2011 - 09:09 AM
I'm not surprised, that was a shithouse explanation even for me...
