pros and cons to commodore stud pattern on lx/lh?
22 replies to this topic
#1 jonesy
jonesy
  • 637 posts
  • Car:hatch
Posted 15 December 2011 - 05:40 AM
as stated in the title i would like a few opinions on the pros and cons to having commodore stud pattern on flared lx/lh?
Edited by jonesy, 15 December 2011 - 05:41 AM.
#2 dattoman
  • 16,487 posts
Posted 15 December 2011 - 09:30 AM
A pattern is a pattern.... the issue is wheel offset if your using factory Commodore wheels
It will look stupid as the wheels on a Commodore are more set in and they won't be filling the guard let alone the flares
#3 ls2lxhatch
  • 5,334 posts
Posted 15 December 2011 - 11:08 AM
+1 Find the wheels you want first, check the offsets available then what patterns they are available in.
It appears that in some states the engineers will not allow re-drilled discs so you would want to have you brake choice sorted before you commit to a stud pattern.
I have Commodore pattern because I wanted to run Commodore rear discs and my wheels were custom made so I could have any pattern or offset I wanted. In hind site for my application I would have been better of using HQ pattern with 1/2" studs which would just require enlarging the holes in the rear Commodore disks. The front brakes are Hoppers which are available in any pattern you want as they have blank discs. The 290 and 330 kits use Ford discs.
Go Ford stud pattern. This gives you off the shelf stock bits for the rear brakes, virtually unbreakable studs, and the greatest range of rims known to man. Ford also has the same centre bore as HQ. So if you are using HQ front discs, just order them blank and away you go. I would use AU on offset as it is closer to Torana than pre-AU. The advantage is the AU wheels will be correctly located on the undrilled HQ discs. This offers several advantages.
Torana offset: +32
AU on offset: +35
pre-AU offset: +6
For the sakes of throwing it in, HQ is +13 and most VB - VZ is +43.
Edited by ls2lxhatch, 15 December 2011 - 11:14 AM.
#4 StephenSLR
StephenSLR
  • 6,714 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 15 December 2011 - 02:35 PM
You can choose BMW rims as they have the same pattern as Commo, they come in a variety of offsets but not necessarily a variety for each style.
s
#5 _Viper_
_Viper_
Posted 15 December 2011 - 03:06 PM
If you o HQ you also get a choice of all the American wheels as it's the same as Chev pattern and they usually have a wide choice of offsets
#6 _CHOPPER_
_CHOPPER_
Posted 21 December 2011 - 10:46 AM
You won't need flares, as you won't find Commodore rims to fill the guards. For comparison sakes, if you go from 13x5.5" Torana rims on torana discs to 15x6" Commodore rims on Commodore (DBA -015) discs, you will reduce your front track by about 10mm.
#7 _sjp67m_
_sjp67m_
Posted 23 August 2012 - 10:41 PM
I presume earlier Chev ?
#8 _LXSS350_
_LXSS350_
Posted 24 August 2012 - 01:11 AM
My advice is pick your wheels and build the car to suit. Wheels are such a personal choice (in their looks) that no one else can make that choice but you. The main reason I prefer HQ (4.75" pcd) is that it is imperial and the optional standard on the Torana (L34/A9X). It also opens up all the wheel manufacturers in the USA as its the very popular chev pattern and early chevs had similar offsets to a Torana. Also I highly recommended an upgrade to 1/2" studs while your doing wheels. For me it's safety first as bigger studs are a cheap insurance upgrade.
#9 _robslxhatch_
_robslxhatch_
Posted 24 August 2012 - 07:20 AM
I went commodore because i am running commodore rear discs, but finding the correct offset wheels second hand was near impossible. If you were having custom wheels made this wont be a problem.
#10 StephenSLR
StephenSLR
  • 6,714 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 24 August 2012 - 07:54 AM
There are some BMW that come close but whether you like the style is another matter.
s
#11 StephenSLR
StephenSLR
  • 6,714 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 24 August 2012 - 07:58 AM
They're not really that much bigger and the wheel isn't supposed to rest on the studs they work in tension not shear. If the wheel is loose and starts wobbling up and down hitting the studs, bigger studs won't help you by much. If it gives you peace of mind ... by all means....
s
Edited by StephenSLR, 24 August 2012 - 07:59 AM.
#12 _LXSS350_
_LXSS350_
Posted 24 August 2012 - 09:39 AM
Having lost a wheel before (at speed) I could never not fit ARP 1/2 studs with their higher tensile strength. Even the dunnydores have gone from 12mm to 14mm studs. That alone should give some clue as to bigger studs being of value. Especially when in manufacturing saving money is such a big issue. Admittedly I do like to drive aggressive and so a strong safe car is of more importance than saving a few dollars. I suppose if your running a banjo/m21 then diff or gearbox will give out before (or at the same time) as the 7/16 wheel studs. :stirpot:
Edited by LXSS350, 24 August 2012 - 09:42 AM.
#13 StephenSLR
StephenSLR
  • 6,714 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 24 August 2012 - 09:54 AM
Losing a wheel wasn’t due to the stud size, more like the bolts were loosened or the wheel wasn’t centred properly and when that happens a bigger stud will not save you.
Not really, The companies engineer the components to suit each other, bigger studs will be fitted to bigger axles, etc. Unless there is a design flaw and they’re known to shear you shouldn’t have to worry about it.
Of course in certain applications where safety is paramount i.e. drag racing, they tend to change the studs after each meet, drag racers replace their diffs just as often as well but they don’t go to a larger size so it’s a different scenario altogether.
Changing your studs more often would be another option to keep safer as metal under tension does fatigue over time, it’s known as ‘creep’.
s
Edited by StephenSLR, 24 August 2012 - 09:54 AM.
#14 _LXSS350_
_LXSS350_
Posted 24 August 2012 - 10:08 AM
Actually they (7/16) sheered straight off. But that's the thing with the latest sticky tyres, 500hp and a manual transmission traction can be hard on gear. Its also why Holden upgraded to 14mm because they are now pushing out far more power than ever before and they are on better tyres. Its all Safety.
#15 StephenSLR
StephenSLR
  • 6,714 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 24 August 2012 - 10:19 AM
7/16 were used on the banjo diff so it's not surprising as they're the bolt for that diff/axle combo.
The BW diffs were stronger and used the 12mm bolt so it's safe to use that bolt for that application.
If you're going to need a stronger diff/axle combo yet again, yeah, you may want to have 14mm bolts.
s
#16 _LXSS350_
_LXSS350_
Posted 24 August 2012 - 10:47 AM
Funny but people spend a fortune on hp and big wheels but forget about brakes,axles,steering etc. Bigger wheels, bigger tyres, more hp, all means more load and stress on components. That's why we go from 28 to 31/35 spline or 280mm rotors to 330 with 4 spots etc.
Bit like my pet peeve of nylock nuts on the steering system. Split pins just give you that extra security. Far too many half as#ed backyard built old muscle cars with big hp motors that shouldn't be on the road. I looked at a lot of cars at the summernats and so many of them are just plain unsafe (look pretty but poorly engineered). It's no wonder we get a bad rap.
Do it properly and do it safe. (faster is good)
Edited by LXSS350, 24 August 2012 - 10:48 AM.
#17 StephenSLR
StephenSLR
  • 6,714 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 24 August 2012 - 11:45 AM
The same goes with engines, many go overboard with the heads, carbs, cams, etc. and forget about the crank and bottom end.
s
#18 _LXSS350_
_LXSS350_
Posted 24 August 2012 - 12:10 PM
Very True. Nothing is cheap about doing old cars up LOL
#19 _CHOPPER_
_CHOPPER_
Posted 24 August 2012 - 09:58 PM
As far as stud size is concerned, just ask my girlfriend. :D
On a serious note, in my 30 years in the tyre industry I have seen literally hundreds of damaged 7/16" UNF and 12 mm wheel studs due to low grade material or dirt caught in the threads. In the same tine I have only seen two damaged 1/2" UNF studs.
Please note that the above statement does not include studs and/or nuts damaged due to improper fitment or nuts being left loose.
#20 _LXSS350_
_LXSS350_
Posted 24 August 2012 - 11:04 PM
Yeh its all about size!
Bigger is better no matter what they say.... LOL
#21 StephenSLR
StephenSLR
  • 6,714 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 25 August 2012 - 06:02 AM
So by 'damage' you mean worn threads?
s
#22 _CHOPPER_
_CHOPPER_
Posted 25 August 2012 - 06:54 PM
Worn, stripped, cross threaded. I've seen it all over the years.
#23 StephenSLR
StephenSLR
  • 6,714 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 06 September 2012 - 07:32 PM
This can affect the tension and a secure wheel is all about having the wheel face pressed hard against the hub surface.
This video may surprise some here
Thankfully in Aus. jobsites all bolts have to be galvanised.
s
Edited by StephenSLR, 06 September 2012 - 07:33 PM.
