you seem to be able to buy the 20mm bush easily. A: can i use this bush for a 22mm bar or B: where can i buy a rubber bush from.
22mm front sway bar bush
etorana
, Jan 09 2012 05:07 PM
4 replies to this topic
Posted 09 January 2012 - 05:07 PM
_les_
Posted 09 January 2012 - 05:24 PM
Are you are talking about a stabiliser "D" bush if so which model Rare Spares has one 9942693 this suits HX HJ it may fit others
Les
Les
Posted 09 January 2012 - 06:11 PM
So what else does it fit,Les?
Its your part,surely you must know.
Im after rubber "D" bushes for a HR sway bar in 22mm.
_CHOPPER_
Posted 10 January 2012 - 12:55 PM
There are two factors in getting the right "D" bushes for your sway bar. The first is the diameter of the bar, the second is whether the bracket is factory or aftermarket.
_les_
Posted 10 January 2012 - 06:43 PM
I know what it was made to fit but I cannot say what else it will fit without testing it they may fit HR it's a matter of trying one
