Super T10 gearbox into LH
Posted 12 January 2012 - 10:44 AM
Posted 12 January 2012 - 10:53 AM
Edited by dattoman, 12 January 2012 - 05:53 PM.
Posted 12 January 2012 - 11:17 AM
Posted 12 January 2012 - 01:04 PM
Posted 12 January 2012 - 01:18 PM
It all depends on which parts you prefer to modify. The tunnel is easy to change if the car is stripped, but the console won't fit with a shifter mounted too high on the side.
edit: the floor was already cut excessively from a previous gearbox, hence the extra large hole
Edited by 76lxhatch, 12 January 2012 - 01:19 PM.
Posted 12 January 2012 - 02:23 PM
Edited by myss427, 12 January 2012 - 02:24 PM.
Posted 12 January 2012 - 05:42 PM
Posted 12 January 2012 - 10:50 PM
Posted 13 January 2012 - 06:45 AM
Yep mine clears at the shifter end easy due to the way I've dropped everything, including cutting the stick mounting holes off the shifter and welding the stick extension on. You will probably have the advantage of a shorter throw with the pivot point higher up (the Hurst mechanism is very short to begin with though so its not too bad). Speco still lists a centreshift shifter on their web site similar to the Aussie 4 speed shifter but I mentioned it on another thread and apparently it is no longer available.76lxhatch, your shifter is a little simpler than the one i did but we achieved exactly the same outcome. Mounting the rods on the inside of the box shift levers save the most room. My shifter body comes through the floor, sits higher and 2 inches to the right. Had to trim an inch out of the standard hole for clearance, just misses the console!
I wonder how long it would take to get used to, interesting thought.You can turn the shift selectors upside down too, and make the box shift upside down. Left down = 1st, up to 2nd, down and across the 3rd, up to 4th. The rods then clear the floor and tunnel.
Posted 13 January 2012 - 08:07 AM
Posted 13 January 2012 - 08:46 AM
I had a HQ Belmont van at the time with a Speco centreshift on a 3spd, and it was 1st left down, across and up to 2nd and down to 3rd, so I was sort of used to 1st being where it was, when I tried this on a Chev and Muncie in a UC I bought once.
Posted 13 January 2012 - 09:57 AM
Posted 13 January 2012 - 11:02 AM
Muncie in the pics above, but they use the same shifters as T10 (one rod is slightly different I think?). Compare to a standard one bolted straight on, they are normally a lot higher. For example compare this to the above pics:ok when you said it ciears at shifter end due to the way you have dropped everything what exactly did you meen & are we talking t10 or tko....... thanks again
The height difference is obvious; also its a little hard to see but the stick sits directly above the shifter, way left.
There are a few threads on here about fitting T10s and Muncies, and the surgery required to the tunnel. Kind of a moot point though if you're going with the TKO now.
Posted 13 January 2012 - 12:05 PM
Posted 13 January 2012 - 01:20 PM
Posted 13 January 2012 - 03:26 PM
Posted 13 January 2012 - 10:43 PM
_robbo_
Posted 25 January 2013 - 09:16 PM
Posted 25 January 2013 - 10:27 PM
Notice there are no dimentions for the floor pan blister.
#21
Posted 26 January 2013 - 06:30 AM
What sort of cross member and how close to lining up are they? Maybe you just have it backwards?same cross member but when i try to fit it in the lh for some reason the hole's would not line up
#22
_robbo_
Posted 26 January 2013 - 06:52 AM
#23
_robbo_
Posted 26 January 2013 - 10:08 PM
a lh i can't find one
#24
Posted 26 January 2013 - 10:26 PM
Edited by myss427, 26 January 2013 - 10:26 PM.
#25
_ht467_
Posted 27 January 2013 - 07:50 PM
I'll see if i can dig it out and post some pics if you're interested?
