Oil sump paint
11 replies to this topic
#1 _keg006_
_keg006_
Posted 31 January 2012 - 10:11 AM
Just wondering on people's ideas about painting the insides of the oil sump. I have modified an oem pan and I want to paint the inside. Recommendations?
#2 _stretchlc_
_stretchlc_
Posted 31 January 2012 - 12:48 PM
ummmm why???.................I suppose you might be able to use Armature Paint, like the stuff some use to paint the inside of their block!!............Still cant work out why though!
#3 _keg006_
_keg006_
Posted 31 January 2012 - 01:06 PM
Wanting to know what people do. And if people do paint tem what is available. My sump will sit idle for a while. So if I am going to paint it rather that leave it raw I would ike to know what to use. I've heard people just leaving them an coating with moly bond dry lubricant
#4 WhaleOilBeefHooked
WhaleOilBeefHooked
  • 1,671 posts
  • Car:LJ GTR
Posted 31 January 2012 - 03:29 PM
A dry lubricant would be much easier. The alternative you mention is mainly used on cast iron blocks to aid in oil drainback, due to the porosity of a hot engine block... Glyptal 1201 red engine enamel is the stuff, but has to be baked on in order to cure......
#5 _oldjohnno_
_oldjohnno_
Posted 31 January 2012 - 06:53 PM
Why would you want to complicate your life by using any sort of coating at all in there? The benefits are miniscule (if they even exist at all) and don't go anywhere near outweighing the various ways in which it can all turn to shit. Wipe it out with an oily rag so it doesn't rust before it's fitted and spend your time researching more productive pursuits.
#6 _stretchlc_
_stretchlc_
Posted 31 January 2012 - 09:21 PM
Thats was along my line of thoughts too Johnno!
#7 _keg006_
_keg006_
Posted 31 January 2012 - 09:41 PM
Thankyou. Bare it is
#8 _Bomber Watson_
Posted 31 January 2012 - 09:55 PM
Although i personally wouldnt, i use Protec Barmastic EMH-375 to paint inside hydraulic tanks at work.
http://www.protec.co...al/w1/i1001570/
#9 hanra
  • 10,992 posts
Posted 16 February 2012 - 10:22 PM
Pulled the sump off my car and I'm not sure it's original.... Was painted black inside and out. Initially it got covered with paint stripper the hit with the gerni, which did sweet f all....
Dropped it in our big paint stripper tank which is full of all kinds of nasty stuff.... And the paint had hardly budged...? After a wash down and dry some paint came off, hit it with the blaster which took a bit more off, but was a struggle... It's back in the effin stripper tank for the weekend....
Must be some sort of hardcore coatig on it??? That stripper tank smashes through paint and powder coat really well!!!
#10 TerrA LX
Posted 17 February 2012 - 07:27 AM
I would have left it on if it was that tough and just painted over the top.
#11 hanra
  • 10,992 posts
Posted 17 February 2012 - 08:45 AM
Yeah I know...now...
#12 orangeLJ
Posted 17 February 2012 - 04:38 PM
once youd had one go at it though, you could never have been sure that it was 100%, so makes sense to persevere and get it all off.
