looking at doing the fuel lines on my lh soon its got a sbc with 550fwhp
I am using an 044 bosch electric pump regulator with return
my question is should I use 3/8 or 1/2 stainless braided line?
Also I have read it is legal to run the braided fuel line true?(Im in qld)
thanks in advance benno
fuel line size?
benno81
, Feb 17 2012 06:32 PM
10 replies to this topic
Posted 17 February 2012 - 06:32 PM
Posted 17 February 2012 - 06:52 PM
Did you consider running alloy tube, nuts and flairs to an fittings on your flexible line??
http://www.summitrac...ng/?Ns=Rank|Asc
http://www.summitrac...ts/?Ns=Rank|Asc
http://www.summitrac...es/?Ns=Rank|Asc
Much cheaper...
As far as size goes, 3/8 should be fine, 1/2 wouldnt be oversized though i recon.
Much cheaper...
_double_d_
Posted 17 February 2012 - 09:08 PM
whats the go with the tubing
it looks like it comes in a roll is that right ?
if so do you have to straighten it somehow ?
looks like a good thing though
ive got a few lines id like to do and move
daniel d
daniel d
Posted 18 February 2012 - 06:46 PM
thanks fellows I just picked up the aeroflow catalogue today and this stuff is in it
double d the line is annealed wich means it can be worked
will be getting a price from a shop here see if its worth while bringing it in from the states
like just about everything I have brought especially chev parts its much cheaper even after postage to buy it from there
the original plan was hilborn injection hence the efi pump but that deal fell through so I brought an 850 ultra hp
any one recomend a pump ?would prefer mech as its easier
_V6 UC_
Posted 19 February 2012 - 12:49 AM
I run aeromotive braid and fittings in my car. The fuel line just comes in a roll and you can straighten and mold it where you want under the car. A single 044 might be at the en of it tether in a setup like that especially if you want to do more work later or run other fuels. I'd recommend 1/2 inch.
_oldjohnno_
Posted 19 February 2012 - 06:09 AM
Use plenty of rubber lined "P" clips to mount it. If you let it vibrate it'll eventually crack near the fittings. And obviously you'll need a flexible connection at the engine end.
Posted 19 February 2012 - 06:57 PM
ok thanks fellows
I just found out aeromotive do a bypass regulator that I can use with the bosch 044 pump well they say any efi style pump to use in carb application.
will be going with that and I would say the hard line anyone put 1/2 line in there torana I m worried about limited space its got a t400 in and 4 into 1 extractors are going to be made and fitted so space will be limited.
_SLR Goat_
Posted 19 February 2012 - 08:19 PM
ive got 1/2 inch in mine i run it along the behind the lip that runs along the bottom of the sill
_SLR Goat_
Posted 19 February 2012 - 08:23 PM
where are you getting the line and fittings from?
_V6 UC_
Posted 19 February 2012 - 09:36 PM
I run 3/8 line, not too much smaller, I just run it along the stock return line with a few of the sharp turns smoothed out, I have a t700 and extractors aswell so also limited room
