No brake lights VX Commodore
8 replies to this topic
#1 _big jack_
_big jack_
Posted 08 March 2012 - 05:49 PM
As the titles says, fuse is OK, could it be the switch on the pedal? Also how the heck do you change the brake light globes? I've undone the 2 Phillips screws on the light assembly i could see but I don't want to break it. By the way it's a sedan. Any help would be appreciated.
Thanks. John.
#2 Potta
Posted 08 March 2012 - 06:13 PM
I think you have to get to the globes from inside the boot.
It could be the switch on the pedal if they are both not working and the fuse is ok.
I'd swap the fuse anyway, cause sometimes they look alright but are not.
#3 mitchg
mitchg
    The guy with the Torailer
  • 3,111 posts
  • Name:Mitch
Posted 08 March 2012 - 06:24 PM
The switch sometimes siezes behind the pedal. Happened on Dads monaro. But it was a $50 switch from holden lol
#4 _Gunmetal LH_
_Gunmetal LH_
Posted 08 March 2012 - 07:13 PM
You can get to the eye-level brake globe from inside the boot. Easiest one to check...
Side brake lights- undo the 2 screws and give the whole light a bump sideways to the outside of the body.
Bypass the brake pedal switch with a paperclip in the plug first and see if they light up.
Edited by Gunmetal LH, 08 March 2012 - 07:15 PM.
#5 REDA9X
REDA9X
    Removed
  • Inactive
  • Pip
  • 0 posts
Posted 08 March 2012 - 07:40 PM
if all your lights are gone it's more than likely a common item like the switch or fuse
#6 tuxedoss
tuxedoss
  • 1,027 posts
  • Car:ss
Posted 08 March 2012 - 08:04 PM
For some reason these commodores go through brake light bulbs quickly, If your high level light is working it will be the bulbs for sure. Once the screws are undone you need to give it a sharp bump with the palm of your hand in the forward direction and the assembly will pop out.. And as Holden always says instalation is reverse of the removal procedure.
#7 dattoman
  • 16,491 posts
Posted 08 March 2012 - 08:22 PM
And when you break the little clips that hold it in... off to the dealer with you
They have wiring loom issues too. ... mostly VT but VX did too
So sometimes you need to replace the short loom too
#8 _Yella SLuR_
_Yella SLuR_
Posted 08 March 2012 - 08:39 PM
If a rear spoiler with brake light, it may be a short in the loom that runs through the boot lid. Pretty common.
#9 _big jack_
_big jack_
Posted 09 March 2012 - 04:31 PM
Thanks everyone for the info.
