Small diameter booster options for LJ?
_Linesy_
Posted 12 March 2012 - 07:14 PM
I have a standard 6 cyl booster in my Lj with 308. I recently went to fit my new rocker covers but they are too tall and the d/s one hits the brake booster.
What are my options for a smaller diameter booster that will fit up to the existing bracket etc?
I know the XU-1 style is an option but they seem a little thin on the ground. I would also like to keep away from remote booster as it may require me to resubmit the car for certification.
Would appreciate any help.
Linesy
Posted 12 March 2012 - 07:15 PM
Posted 12 March 2012 - 08:11 PM
Anything smaller will give less boost
The XU1 booster isn't smaller so thats not an option anyway
There is an 8" hotrod style booster I have used before on Fords.. .but it means changes to master and plumbing too...aswell as adapting the booster to the bracket
Bit of an exercise
_Linesy_
Posted 13 March 2012 - 03:17 AM
thanks for the replies guys. My error on the XU1 booster, not sure why I thought it was a smaller diameter. I am ok with plumbing changes if necessary.
Perhaps remote is the best option???
Posted 13 March 2012 - 08:41 AM
So the cost gets up there
Budget over $1000 if using new parts. .... just to clear rocker covers ??
Doable... but you need to weigh up your options
_Linesy_
Posted 13 March 2012 - 12:37 PM
Was hoping to find a cost effective solution to achieve the desired result. Unfortunately that may not be possible, so I will consider modifying my covers.
Linesy
_hardie355_
Posted 16 March 2013 - 05:47 AM
Hi linesy,
Im having the same trouble at the moment, have you got your sorted yet if so would you mind putting up a pic.
Ian
_shan620_
Posted 17 March 2013 - 04:13 PM
_Linesy_
Posted 27 March 2013 - 07:01 PM
Not yet, My oil leak fix turned into a bit more than expected - repaint engine bay, strip xmember etc lol, sure you know how it goes.
However I have been talking to a chap that fitted some sort of Mitsi lancer (he thinks) booster.
Seen the photos and it looked good and he reckoned it fitted up no probs, also used std mastercylinder.
I'm not far from sorting it = will update as and when I get there
