202 carby set-up WW Stromberg or 350 Holley or ?
Posted 21 March 2012 - 04:20 PM
I am going to fit extractors to my wife's LX Hatch and as I've had a bit of trouble with the single choke Stromberg on it, I want to change to a double choke carby.
Other than the extractors and double choke carby, the motor will be stock.
Thought of WW Stromberg off a 186-S/LC GTR or a 350 Holley so who has this combination on their 202 or is there something better?
Any tuning troubles with any of these as I'd like something reliable and easy to look after.
Regards ... Barry
Posted 21 March 2012 - 05:01 PM
http://www.gmh-toran...er/page__st__25
Posted 21 March 2012 - 05:50 PM
G'day Barry, not sure about the holley on a standard motor, but i put a ww on my stock 173 in the uc when i fitted extractors, runs great and has a bit more go. pics here...
Thanks Stinga
I've copied the pics of the set-up as as the 186-S did have a rod linkage for the throttle.
Regards .... Barry
_Moose lc_
Posted 23 March 2012 - 10:07 PM
Moose
_Moose lc_
Posted 23 March 2012 - 10:26 PM
http://holdenpaedia.....com/350_Holley
Worth a look if nothing else
Moose
Damn! That's *lied* by the way. I hate typos! Just too bad I'm so good at them. Lol
_oldjohnno_
Posted 24 March 2012 - 07:46 AM
_Moron_
Posted 24 March 2012 - 12:38 PM
I had an ADM on a Lynx manifold mated to a 173 (now on a 202) which runs pretty well. They came out on the 6 cyl XE/XF Falcons so are pretty common.
Used to run a bit rich on the 173 and so it'd bog down once the secondary opened up but was otherwise pretty reasonable on fuel. Runs even better on the 202 - haven't even touched the jetting. Although I've been told mines off of an ex-cop car and has different jets standard. YMMV.
They are pretty cheap to buy and pretty simple to bolt up in my experience as well.
More info here:
http://holdenpaedia....eber_Conversion
There's also a service manual floating about on www.xfalcon.com
Out of curiosity has anyone tried a Carter 2 barrel off of some of the slant sixes on a Holden? Are they a progressive 2 barrel or are they more like the holley?
_Moose lc_
Posted 26 March 2012 - 05:26 PM
Moose
_oldjohnno_
Posted 26 March 2012 - 06:10 PM
_tyre fryer_
Posted 27 March 2012 - 05:17 AM
Posted 27 March 2012 - 08:15 AM
Posted 27 March 2012 - 11:21 AM
I did have one on my ex HR 186-S Premmie and it worked good.
Hope to have it fitted up with the extractors in about two weeks after the traumatic is replaced.
Regards .... Barry
Posted 03 April 2012 - 12:56 PM
Johnno, you've got it the right way round.I really doubt that whoever wrote that jetting chart has really tested it on various engine sizes. I've always found - without exception - that a given carb size will want more mainjet when used on a smaller engine and vice-versa. But this chart has it the other way around. WTF?
Barry,
you may find you want one size bigger in main jets or you'll get that flat spot mentioned above.
With the 230 stroker I went up two sizes (51 I think).....just look at a comparable size engine that used the WW and use the jets they had. Many Frauds used the WW on big sixes.
If you had been wanting to go Holley, I would have suggested throwing the 350 and using a 390 Vac Sec......runs about the same CFM as a WW when it's only on the primaries. Much better tunability and fuel economy possible with the 390 over the 350.
Mail order??...you could have had a nice drive up the freeway and had a cuppa with the old folks!!
Grant..
Posted 31 August 2012 - 09:30 PM
Hi Barry,Thanks all for those comments but in a few days there will be a reco'd WW strommy/manifold at my door c/o xtreme fuels systems in Campbelltown.
Regards .... Barry
have you got any pics of the recon WW on your motor. I'm looking at this set-up too.
Marty
