Opinions on carter fuel pumps
_SLR Goat_
Posted 09 April 2012 - 05:22 PM
http://www.ebay.com....=item27ad09efbc
I run a 1/2 inch fuel line with a holley reg atm no return line will this affect the pump at all engine is a very warm 308 will i still need to run a reg have being looking on ebay for info but different sellers post different specs for the same model pump which gets confusing
cheers in advance for any info
_oldjohnno_
Posted 10 April 2012 - 07:12 AM
If you spend some time setting up some soft rubber mounts for it they can be very quiet as well.
_LJ355_
Posted 10 April 2012 - 08:11 AM
they do come with rubber mounts
Posted 10 April 2012 - 07:01 PM
Quite a few mates run the same pump, and they're all happy. Definitely way quieter than Holley's. If you mount it right, and gravity feed it, you'll be fine.
_SLR Goat_
Posted 12 April 2012 - 09:02 AM
_ass308_
Posted 13 April 2012 - 08:20 AM
_double_d_
Posted 13 April 2012 - 08:24 AM
is a little noisy to start with but seems to quieten down after a few minutes
i looped the fuel lines at the inlet and outlet so fuel doesn't drain out of the pump when turned off
but is quieter than the holley i had before
daniel d
Posted 15 April 2012 - 11:04 PM
_SLR Goat_
Posted 30 August 2012 - 04:36 PM
cheers in advance
Posted 31 August 2012 - 10:01 AM
I have a 4070 which supplies the Quadrajet nicely with no additional reg or return line, I fitted it to fix a starvation problem with emptying the bowl and its been perfect ever since.
_SLR Goat_
Posted 31 August 2012 - 04:22 PM
1/2 inch is the size I was advised to run for my engine besides thats not the issue the pump specs say 8psi I only get 3psi which dosent change with engine running or not running
Posted 31 August 2012 - 04:34 PM
edit: unless your needle and seat isn't sealing properly?
Edited by 76lxhatch, 31 August 2012 - 04:34 PM.
_SLR Goat_
Posted 31 August 2012 - 04:58 PM
Posted 31 August 2012 - 08:38 PM
But i ran a kit through it - see http://www.summitrac...ts/CRT-888-178/
and it is now around 7psi
_oldjohnno_
Posted 31 August 2012 - 08:59 PM
Posted 04 September 2012 - 09:35 PM
2 gold as pick up pumps, 1 black to feed engine
