Cam shaft removal 186
17 replies to this topic
#1 _glennhailstone_
_glennhailstone_
Posted 30 April 2012 - 12:15 PM
Hey everyone,
I am having difficulty removing the cam shaft from my 186.
I can't turn the cam gear to get access to the two locating screws behind the cam gear. The annoying thing is they are only about a hole out.
Thanks,
Glenn
#2 _grumpy 026_
_grumpy 026_
Posted 30 April 2012 - 01:12 PM
Glenn,
I assume motor is seized if it can't be turned to line up the holes to get at the cam retainer bolts. Other wise keep turing till they do.
If seized and you want the cam, drill or grind out the holes to get at the bolts,and the replace the cam gear with a new one. G.
#3 _glennhailstone_
_glennhailstone_
Posted 30 April 2012 - 03:01 PM
Hey G,
I don't think its seized because I could turn the crank by the fly wheel when it was attached, but I can't get any leverage now.
#4 _double_d_
_double_d_
Posted 30 April 2012 - 03:38 PM
take the plugs out ?
daniel d
#5 _Inj gtr202_
_Inj gtr202_
Posted 30 April 2012 - 05:30 PM
As said, Plugs out, if you got a manual put in fourth gear and give the car a bit of a shove, should free it up.
#6 _stretchlc_
_stretchlc_
Posted 30 April 2012 - 06:51 PM
Why not put the balancer back on the key and try spin it from the crank pulley??.........All you have to do is spin it a few cms. to line up the 2 holes in the cam gear....If you can turn the carnk pulley the cam will follow!!...........Is the head, lifters and oil pump still fitted to this engine?
#7 _Quagmire_
_Quagmire_
Posted 30 April 2012 - 09:32 PM
put two lywheel bolts back in on oppisite sides parralell to each other and use a long screwdriver or crow bar to turn it
#8 _glennhailstone_
_glennhailstone_
Posted 01 May 2012 - 06:45 AM
Hey thanks for all the advise guys,
I should have said the head is off and its on an engine stand, so no flywheel. I tried putting the balancer back on but I still couldn't get leverage. I might have to try a bit harder, but I don't want to F anything.
Thanks again
#9 _double_d_
_double_d_
Posted 01 May 2012 - 07:17 AM
put the balancer back on and put the three puller bolts in it
then turn it with a screwdriver inbetween those bolts
#10 _glennhailstone_
_glennhailstone_
Posted 01 May 2012 - 12:09 PM
Thanks Stretch and DD, I did that and it worked!
Now next problem, The book says slide cam shaft out, but its hitting something and only moves about 10mm. The only thing left on the motor is the oil pump, pistons and crank. There is a little gear by where the dizzy goes, is this stopping it.
Thanks again for all the help peps
#11 _stretchlc_
_stretchlc_
Posted 01 May 2012 - 01:13 PM
You have to pop all the lifters out of their bores and take the oil pump off too...That cam WILL NOT slide out with the Oil Pump still bolted to the engine....It should slide out really easy then, but be real careful sliding it out as you wont want to score the cam bearings.
Slow and Steady mate.
#12 _double_d_
_double_d_
Posted 01 May 2012 - 06:08 PM
yup the little gear you see is the oil pump thats what is stopping you
daniel d
Edited by double_d, 01 May 2012 - 06:08 PM.
#13 S pack
  • 15,736 posts
Posted 01 May 2012 - 09:55 PM
Insert your middle finger in the vacant oil pump hole in the block to support and help guide the cam out through the bearings.
When you get the cam halfway out of the block then move your finger up to the fuel pump opening
Reverse the same procedure when you insert the new camshaft.
#14 _glennhailstone_
_glennhailstone_
Posted 02 May 2012 - 02:03 PM
Ok thanks,
I can't get the oil pump out though, I have taken out the four main bolts and I have taken the cover plate off but its very tight coming off.
#15 _double_d_
_double_d_
Posted 02 May 2012 - 05:57 PM
i just took one off this morning needed a lot of twisting , pulling and prying
but came out was real tight though
daniel d
#16 S pack
  • 15,736 posts
Posted 02 May 2012 - 07:17 PM
The pump gaskets have probably been coated with gasket goo which has adhered the pump to the block.
I've found it advantageous to leave the oil filter on the pump to help give some leverage.
#17 orangeLJ
Posted 02 May 2012 - 08:49 PM
Once you have the oil pump out, you will have to lift each lobe through the cam bearing holes, so its not just a case of pulling, more a slow up and down and guided process, lots easier with the engime upside down and the sump off.
#18 _glennhailstone_
_glennhailstone_
Posted 03 May 2012 - 05:28 PM
Thanks for all the helpful info..
