on a lean
Posted 24 May 2012 - 03:47 PM
The car seems to be sitting higher on the drivers side front and rear by a noticable amount. as far as i can tell the srings are seated right.
as im going to get a roadworthy on the car sometime in the next few months i need it fixed does anyone have any advice on this?
Posted 24 May 2012 - 04:33 PM
_robslxhatch_
Posted 24 May 2012 - 08:17 PM
_likatiger_
Posted 24 May 2012 - 09:19 PM
Posted 24 May 2012 - 09:32 PM
Posted 16 December 2012 - 01:20 PM
i've changed a dozen or so front and rears over the years and the young blokes LH has me stumped.
Car was flat before we started.
I've removed and replaced the k frame with a new k frame that i have bench restored.
Diff also in and out.
Brand new lovels springs all round.
Car got dropped on all fours a week or so ago and sits on a shocking lean.
Clear inch and a half up in the front left
down a half inch right rear.
done the usual, jacked back up , confirmed springs sitting over the fingers correctly, springs sitting on the locating holes in the same spots.
bounced the bejesus out of it.
can't see 40mm of cockup in it.
has me stumped.
_LS1 Hatch_
Posted 16 December 2012 - 01:32 PM
Make sure none of the bushes or ball joints are binding either and causing it to not settle maybe ?
Posted 16 December 2012 - 08:17 PM
Posted 16 December 2012 - 08:26 PM
having looked at that, pics are uselesss.
Trust me , passenger front is an inch and a half higher
_CraigA_
Posted 16 December 2012 - 08:31 PM
Posted 16 December 2012 - 08:33 PM
Posted 16 December 2012 - 09:22 PM
Lovells are inch low
Control arms are fine, certainly not bent enough to cause the inch and a half difference R to L
Posted 16 December 2012 - 11:14 PM
I presume you didn't torque up any of the suspension bush bolts (front and rear) before you dropped it back on the ground.
Posted 17 December 2012 - 10:42 AM
Must say i've been concentrating on the fron, but might have a closer look at the arse
Posted 17 December 2012 - 11:09 AM
When you jack the front wheels off the ground the wheels swing in toward each other. When the car is lowered back onto the ground the front of the car will sit high and possibly on an odd angle until the wheels are able to move out.
You could try making your own wheel alignment slip plates too allow the suspension to settle without driving. Two plates of metal, wood or floor tiles with grease between them will do the job. When you bounce the car on slip plates you should see them move in and out.
Edited by ls2lxhatch, 17 December 2012 - 11:13 AM.
Posted 18 December 2012 - 11:07 AM
Posted 18 December 2012 - 01:53 PM
Like i said earlier, i've done this job many times, never had a difference this dramatic
Posted 18 December 2012 - 05:46 PM
What shockies are in the Torana? Oil or gas, old or new?
Posted 18 December 2012 - 06:23 PM
Posted 18 December 2012 - 07:48 PM
brand new Konis were fitted, they are out of the car in the picture as i wanted to confirm the spring was seated correctly.
Cheers, it was just a thought.
#21
Posted 18 December 2012 - 09:10 PM
all i've come up with is 2 different sprin gs in the same box, except they have the same stickers on them
#22
Posted 18 December 2012 - 10:20 PM
appreciate the thought,
Time to pull the springs back out, measure them up to see if they are the same and then swap them around and see if the cars stance changes.
If the rears check out ok then it would have to be the front springs causing the problem?
#23
Posted 19 December 2012 - 08:04 PM
#24
Posted 26 December 2012 - 09:16 PM
so we replaced them with another pair i had here and presto, fixed the issue.
Now to deal with wa suspensions for a refund..........
#25
_Emu_
Posted 26 December 2012 - 10:41 PM
Typical useless muppets. No wonder everyone buys everything they can from the states :(
Good job fixing it though...
