engine choice
#1 _Bigmac123_99_
Posted 06 June 2006 - 10:31 PM
heard a fedw diff oppinions. what is the better chioce to put into my lh, a modyfied 186 or a modded 202 and why??? thanks
#2 _Keithy's_UC_
Posted 07 June 2006 - 08:11 AM
If you like to rev without throwing conrods, then go the 186. If you want to supercharge it, go the 202!
Due to a better bore vs stroke ratio, you can more safely rev the tits off a 186 than a 202, but thats not to say you cant do it in a 202, you just have to make sure you build the bottom end up nicely!
Stock versus stock, i'd go 186.
For towing, i'd go 202.
For highway, i'd go 186.
For city, i'd go 186.
For racing/revving, i'd go 186.
Oh.... HANG ON.... I've got a 179HP bored to...... 186!!
Cheerio
Keith
Edited by Keithy's_UC, 07 June 2006 - 08:12 AM.
Posted 07 June 2006 - 12:05 PM
CHEERS Chris
P.S. another point is that i am planning to supercharge, should be done in the next 12 months! sweet as mate.
Edited by orangeLJ, 07 June 2006 - 12:12 PM.
Posted 07 June 2006 - 12:28 PM
Keith, you seem to like the 186 a lot.
I agree that the 186 does have some advantages over the 202, especially when you're going to give it a boot full, but I'm having trouble seeing how a 186 would be better than a 202 for city & highway driving. The 202 has a clear advantage in mid range torque, so for city & highway usage in the 2,000 to 3,000 RPM range, the 202 would perform better & return better economy that the 186.
Dr Terry.
Posted 07 June 2006 - 03:00 PM
if you have the money I would do a 202, simply because of the extra cubes.
saying that though, I am building a 186 for dads LC. But with a heavier car like a LH the extra cubes and torque would come in handy
Edited by makka, 07 June 2006 - 03:01 PM.
#6 _Sammy_
Posted 07 June 2006 - 03:04 PM
i've had a 192ci motor which went very well, 6000rpm was about the end of the cams power range, i rebuilt a 202 with a good bottom end and put the same head and cam in it that was in the 192 and it didn't seem to be any different as far as revs were concerned, revved to 6500rpm more than once (not that it was making alot of power there) but the thing i did notice is it was alot better off the line, and low down in the revs just seemed to go better .... maybe the blue 202 crank being counter weighted had something to do with it, but for my money i'd go the blue 202 any day for a street motor ....
as for racing ... well i dunno, probably 202 because more cubes
#7 _Keithy's_UC_
Posted 07 June 2006 - 04:10 PM
After having both engines in my UC (202 and now the 179), i have experienced both sides of the fence so to speak! While the 186 has its disadvantages, i believe that the head and rocker setup on the 186 is also more reliable. Before anyone says that you can swap them, i know and understand its possible, but when it comes down to longevity of your motor and the ability to use the upper rev range, the 202 ran out of puff where the 186 is loving it! Torque is the difference, so towing yep, but in the city i'd go the smaller cubes with the ability to pick up and go.
Maybe im now biassed (probably the truest thing ill ever say!!), but the 202 always seemed to feel sluggish even after a dyno tune whereas the little revver just keeps going. And i cant feel the difference in torque between the two. As it happens, i cant launch my 179 powered UC with anymore than 1500rpm unless i like spinning the tyres. Even with a car full of people. The 202 was a struggler and never wanted to haul.
BUT...
My 202 was stock and my 179 is worked, and when built correctly im sure a 202 would sound no different, go just as hard if not harder, and return virtually the same fuel consumption too!
Personal choice, but im sticking with a bottom end thats not gonna fall apart!
Does anyone know the stock for stock power and torque of both a 186 and a 202??
Keith
P.S. I have a 202 sitting on my engine stand which ANYONE can have for free if they want! No dizzy or exhaust manifold or carby!
Edited by Keithy's_UC, 07 June 2006 - 04:13 PM.
#8 _Loki_
Posted 07 June 2006 - 05:25 PM
Gee wow, I'm sure I'd prefer a jet engined F22 over a Prop'd Spitfire tooMy 202 was stock and my 179 is worked, and when built correctly im sure a 202 would sound no different, go just as hard if not harder, and return virtually the same fuel consumption too!
Comparing a worked 186 to a stock 202, apples and oranges.
Dr T. is right about the torque for fuel economy (if such a word exists in these engines)
Edited by Loki, 07 June 2006 - 05:27 PM.
#10 _UCV80_
Posted 07 June 2006 - 07:27 PM
ya really cant compare a stock 202 to a worked up 186
big or small with the right work they will both be rockets.
Edited by ToranaZ, 07 June 2006 - 07:30 PM.
#11 _73LJWhiteSL_
Posted 07 June 2006 - 09:25 PM
I don't think you can compare a stock Holden 6 anything to a worked Holden 6 anything...
Steve
Posted 07 June 2006 - 09:31 PM
Edited by makka, 07 June 2006 - 09:32 PM.
#13 _Pedrobully_
Posted 09 June 2006 - 10:10 PM
#14 _Bigmac123_99_
Posted 09 June 2006 - 10:29 PM
well there has been some update on my engine situation. i am no longer getting a 202 blue.
I have purchased a T/D Race engine which is brand new and only done bout 20mins on the dyno for tunning. Know a guy who used to have a racing team (which he no longer has) and this was his spare motor he built. i got it off him. got high pressure fuel & oil pump. getting electronic ignition, 350 holley but i do not know what mnifold to go with. the dude suggested i get a kane?? manifold but i am having trouble getting any info on these. any alternative choices would be appreciated..
chris.
Posted 10 June 2006 - 03:22 PM
what race class is T/D?
is it a 202?
#16 _Bigmac123_99_
Posted 11 June 2006 - 12:11 AM
#17 _Sammy_
Posted 15 June 2006 - 01:31 PM
yeah i have a blue 202 crank and rods in a red 202 block ... reason for this was the blue block was worn, already had the virgin bore red 202 so i got it bored to fit my blue bits!Has anyone looked at putting a 202 blue crank in a 202 red ??
#18 _73LJWhiteSL_
Posted 15 June 2006 - 03:23 PM
Steve
#19 _Sammy_
Posted 16 June 2006 - 01:49 PM
also it depends which block you have, if its got the rope seal then that should work with the blue motor ... otherwise i don't think it will.
#20 _Oldn64_
Posted 16 June 2006 - 02:50 PM
#21 _Sammy_
Posted 30 June 2006 - 03:41 PM
#22
Posted 30 June 2006 - 03:53 PM
#23 _Sammy_
Posted 04 July 2006 - 08:57 PM
#24 _wasted_youth_
Posted 07 July 2006 - 08:41 PM
