Painting metal parts
_judgelj_
Posted 19 June 2012 - 08:41 PM
Been reluctant to ask this for a while now but i've had no luck finding what i needed. Perhaps it's easier for me to ask specific questions.
What i want to know is what sort of prep should i undertake and what paint is needed when restoring metal parts such as foot pedals, shifters, seat frames etc. These are your average bits and pieces that over the years have lost their finish. My old method would have been to give a light rub back and spray with fiddly bits enamel but this has proved to be a bad idea with regards to longevity. Everything eventually flakes and scratches and i want something that is a bit more hard wearing, with a nice smooth finish.
So, what type of paint should i use? Is enamel ok? Do i need to use a primer at all? How do i go about sanding in between coats?
Cheers guys appreciate the information!
Posted 19 June 2012 - 08:46 PM
That said, i like to use engine enamel for pretty well everything, its really tough for a pressure pack product.
REst of your prep sounds good, sand, clean, spray. Depending on the product primers are either needed or not, for your regular pressure packs then you will need them, for something like engine enamel it should be fine to go strait on.
Posted 19 June 2012 - 08:50 PM
Edited by ls2lxhatch, 19 June 2012 - 08:52 PM.
_judgelj_
Posted 19 June 2012 - 10:09 PM
I might think about POR15, i have a similar product from the states but im not sure how it would look painted on?
Posted 19 June 2012 - 10:12 PM
Some are just garbage, and compared to proper coatings there all garbage, just depends on how carried away you wish to get.
For parts like you suggested any of the above options will be fine.
Wet sanding between coats would be ok if you leave it to cure properly, thats getting very keen though lol.
_judgelj_
Posted 20 June 2012 - 09:39 AM
Posted 20 June 2012 - 06:25 PM
_judgelj_
Posted 20 June 2012 - 07:05 PM
Posted 20 June 2012 - 07:13 PM
A lot of those pressure pack primers do more harm than good.
Posted 20 June 2012 - 07:14 PM
_judgelj_
Posted 20 June 2012 - 09:53 PM
Posted 20 June 2012 - 10:13 PM
_Quagmire_
Posted 20 June 2012 - 10:35 PM
_judgelj_
Posted 21 June 2012 - 11:16 AM
Posted 22 June 2012 - 04:11 PM
_judgelj_
Posted 22 June 2012 - 06:02 PM
Posted 22 June 2012 - 08:15 PM
