carby spacers
_lh.355_
Posted 23 June 2012 - 11:31 PM
_ljxu1torana_
Posted 23 June 2012 - 11:45 PM
personally i dont think it is not going to make much difference,with a 465 holley and a 253.just my thoughts.thanks jason.Hi, just wondering what peoples thoughts on carby spacers. I am putting a holley 465 on my lx 253 and thinking about a 1" spacer . what would be the diff between a super sucker or plain square and 1" verse 2" spacer .fitting it on elderbrok performer mild cam etc.
_lh.355_
Posted 24 June 2012 - 12:06 AM
_ljxu1torana_
Posted 24 June 2012 - 01:05 AM
i think that you have answered your own question.thanks jason.think i might be trying to be sold some thing i really dont need .cheers
_Yella Fella_
Posted 24 June 2012 - 01:09 AM
Edited by Yella Fella, 24 June 2012 - 01:11 AM.
_Viper_
Posted 24 June 2012 - 02:09 AM
_LH8VD69_
Posted 24 June 2012 - 02:29 AM
I had just rebuilt my 308 in my VH Commy in line with a full resto and the engine was not only NOT making good power but didn't rev as free as it should considering the engine specs. I took it to several different places both in Kalgoorlie and then Perth WA with no luck.
I had pretty much resigned myself into having to just live with this engine when I came across an old guy at a tuning shop here in Perth that said he would take a look.
Well I picked the car up late in the arvo and boy was I happy. Sure the car needed some fine tuning but what actually 'fixed' it was a 1" carby spacer ! The engine pulled like a train and reved freely to 7200rpm.
What can I say but
Posted 24 June 2012 - 09:15 AM
_Yella Fella_
Posted 24 June 2012 - 09:30 AM
Posted 24 June 2012 - 02:13 PM
Check out Bocam Engineering
Handy for keeping alittle heat out of the bowls
_LS1 Hatch_
_lh.355_
Posted 24 June 2012 - 03:40 PM
Posted 24 June 2012 - 03:56 PM
Sadly i cant tell you from here what primary jets your going to need in the carby, you will have to buy several to find the correct one, same deal with a carby spacer.
Posted 24 June 2012 - 04:09 PM
You need a dyno to see which spacer if any work for your engine.
Posted 24 June 2012 - 04:14 PM
Sometimes they work,sometimes they dont.
Borrow one to try if you can.
The best dyno is 1/4 mile long.
_Yella Fella_
Posted 25 June 2012 - 12:10 AM
Notwithstanding that, my car seems to go better with the standard gasket? Don't know if there is a link.
Posted 01 July 2012 - 12:49 PM
i was thinking that i have to fit a pcv valve port in and i might as well put it in a 2" spacer
any help would be good
do i need to put a pcv valve in will it run any better??
Posted 01 July 2012 - 12:51 PM
_lh.355_
Posted 01 July 2012 - 06:32 PM
_TorYoda_
Posted 04 July 2012 - 10:40 PM
Spacer requirements are directly related to the manifold plenum volume and shape but it is not an exact science because carb sizes and cam durations affect what works best as well. Testing all the combinations in the real world is unfortunately the only way to find what works best for your particular combination. Jetting must be revised for each change in order to make accurate comparisons.
Edited by TorYoda, 04 July 2012 - 10:42 PM.
