202 engine weight
5 replies to this topic
#1 _hybird_
_hybird_
Posted 04 July 2012 - 04:17 PM
gday all,
just wondering if anyone can confirm that the 202 xu1 motor is supposedly only 20 kilos lighter than a bog stock 308 motor.just looking at weights in a lj torana,and i know you need engineers report etc
#2 r2160
r2160
  • 712 posts
  • Name:Glenn
  • Car:2/71 LC GTR, 4/71 LC 4 'S'
Posted 05 July 2012 - 08:04 AM
From what I know, the red 202 comes in at 250 kg
Glenn
#3 Peter UC
Peter UC
  • 770 posts
Posted 05 July 2012 - 12:24 PM
Use the search this has been covered many times, and it not anywhere near 250kg, probably about 180kg complete
#4 ls2lxhatch
  • 5,334 posts
Posted 05 July 2012 - 01:41 PM
There was no definitive answer in last thread.
http://www.gmh-toran...2-engine-weight
Somewhere around 150-160 kg seems to be in the ballpark. It will depend on how the engine is dressed.
I can not remember where the following figures for the 308 came from or whether it included manifolds, alternator, starter, flywheel.
308 dry 495 lbs/225 kg
The difference between the kerb weight of a 6 cyl SS and a V8 SS is published at 30 kg. It would be reasonable to assume most of the 30 kg is in the V8.
Edited by ls2lxhatch, 05 July 2012 - 01:46 PM.
#5 _PeteXU1_
_PeteXU1_
Posted 05 July 2012 - 05:44 PM
If you subtract 25% from the 308 engine weight (the extra 2 cylinders) it should work out about right. Also depends on what valves are fitted.
#6 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 05 July 2012 - 06:30 PM
depends if the oil is on the add, or full too..
