Yella terra Bennett hi-port or COME 2004 heads
_355lxss_
Posted 02 December 2005 - 01:12 PM
Cant find much info on the yella terra ones except that it got 490hp out of the box. Ive read a bit on the COME 2004 which sound impressive, 580hp unported out of the box using 2.02 valves.
Would like to know hp/torque performance differences.
_HatchmanSS76_
Posted 02 December 2005 - 04:19 PM
Posted 03 December 2005 - 08:32 AM
Cast iron VN heads will get your LX well into the tens over the quarter. This is fast enough for you to require a roll cage, tech inspection, UDL etc (read more $$$).
Both the alloy options are expensive and (YT at least) require special rockers.
Don't spend money unneccesarily just so you can say "I've got alloys !!"
_Lostit_
Posted 03 December 2005 - 03:56 PM
Now this package in a LX will run high 10's on the strip all day long once it hooks up.
To have this sort of motor on the road you will literally blow most things away on the road including big bikes .. unless of course they know how to ride.
But at the same time it will be heavy on the Fuel.. but hey ...... but you still looking at $30K to build a tough reliable car these days.. and that hasnt touched the paint,interior ,etc.
Denis
_MAWLER_
Posted 03 December 2005 - 05:58 PM
Peace.
_CHOPPER_
Posted 03 December 2005 - 07:55 PM
And it costs $35K for a stock Commodore, so it's not that bad when you look at it that way.But at the same time it will be heavy on the Fuel.. but hey ...... but you still looking at $30K to build a tough reliable car these days.. and that hasnt touched the paint,interior ,etc.
_355lxss_
Posted 05 December 2005 - 03:01 PM
For a little more cash i thought the alloys would be the way to go due to the fact that i can save some weight in the front end of the car, and being alloy i would of thought that it would disperse the heat better and cool down quicker?
The aim is to make 500-550hp at the flywheel.
What do the cast vn heads flow as std from factory?
Posted 05 December 2005 - 04:19 PM
$900 of port work got standard valved heads to flow 249cfm @ 25" or 541HP.
These heads on a 355 stroker I assembled with 9.8:1 and a 255 @ 050 solid made 475HP on Sams Performance engine dyno (Sydney).
A month later in a VK Calais it ran 11.4 at only 114mph running out of fuel on its first pass.
This combo would run a mid to high 10 in a well set up LX easily. Want to go faster??? More comp, cam and converter will do it but at a price.
Standard VN heads flow about 440 HP
Hope this helps.
_355lxss_
Posted 06 December 2005 - 12:10 PM
Thanks for that struggler what was the sort of example i was after. Going by those figures the engine will still need to make a good 500hp to crack a low 10 in a torrie. Dont think a torrie hatch is that much lighter than a vk, 20kg difference?
_MAWLER_
Posted 06 December 2005 - 05:28 PM
Cheers,
_1QUICK LJ_
Posted 18 April 2009 - 04:55 PM
_355lxss_
Posted 04 August 2009 - 02:52 PM
_rollo_
Posted 05 August 2009 - 11:44 PM
_355lxss_
Posted 06 August 2009 - 09:25 AM
What sort of torque did your SAMS performance 355 make?
_rollo_
Posted 06 August 2009 - 02:33 PM
Unfortunalty we don't have a track in Adelaide to race, the SA government thinks we don't need one!!!! Yes the engine combo changed in the end. ended up building more of a streeter than a race engine. Ended up with a 355, tp high-rise duel, crane f280 solid 10.8 to comp. engine still made decent hp and tq, 470hp @6900 and 420ftq @4100. should be good for a low 11 pass, thats if we ever get a track happening here in Adelaide?
dont quote me but from memory i think it was about 500
_355lxss_
Posted 08 August 2009 - 01:48 AM
_gmlj6_
Posted 12 August 2009 - 07:52 PM
_RUN-010_
Posted 01 December 2009 - 03:58 PM
id go alloy. probly the yella terras also. alloy out the box flows as much as a ported cast iron head would. at about the same price
Hi ILH 355 can you gives us a run down of the 355 built by sam
Posted 02 December 2009 - 11:51 AM
Having had both I know which I would do again!
On the heads topic - the unported 2007 COME alloys were added to the 383 replacing well ported VN iron heads. Allowed comp increase from 10.7 to 11.3. Made lots of extra torque, especially mid range torque and were well worth the money in my opinion.
