Sandblasting
#1 _trav_
Posted 08 June 2006 - 01:48 PM
I am just wondering what exactly sand balsting is and does?? I have heard of people taking stuff down to sand blasters but never asked them what they were taking...I am just wondering what type of stuff you can get sandblasted and why people do it...like what is the end result??
trav
Posted 08 June 2006 - 02:01 PM
Edited by smeer, 08 June 2006 - 02:02 PM.
#3 _jabba_
Posted 08 June 2006 - 10:26 PM
Posted 08 June 2006 - 10:46 PM
Now use copper slag or glass or a nut shell.. that i just can't think of at the moment
Can blast most things metal, alloy and even timber but not plastic as it will just chew through it.
Good for getting into corners and hard to reach places.
End result is a very clean and fairly roughed up surface.
But is a fairly messy clean up after, specialy on body's as grit gets everywhere and seems to just keep reappearing specialy when blowing around a bit of paint.
Care must be taken on thin or very rusty parts as holes can be blasted right through them... also through fingers and other body parts.
#5 _munro_
Posted 08 June 2006 - 10:56 PM
it's brilliant for cleaning up pitted metal
#6 _troy_
Posted 08 June 2006 - 10:59 PM
Posted 08 June 2006 - 11:38 PM
I�ve also heard it work hardens the metal.I worked for a sand blasting company and this bloke i was workin with sandblasted his whole HG ute then spent $5000 on painting the car tried to put it back together and it was all stretched due to the metal being heated up during blasting!!
A friend had a pair of original 28 ford roadster front guards done and they finished in the bin, had to buy aftermarket ones, he was pissed off!
"Damn sand gets in everywhere" heard that somewhere before.
Anybody had dealings with chemical stripping?
#8 _jabba_
Posted 09 June 2006 - 07:58 AM
#9 _trav_
Posted 09 June 2006 - 12:31 PM
trav
#10 _munro_
Posted 09 June 2006 - 01:54 PM
exept for [SIZE=7]bloody sand everywhere[SIZE=7][SIZE=1]
but all i do is blast areas affected by rust
cheers tom
Posted 09 June 2006 - 10:07 PM
#12 _trav_
Posted 10 June 2006 - 03:26 AM
trav
Edited by trav, 10 June 2006 - 03:26 AM.
Posted 10 June 2006 - 04:11 AM
#14 _Hotrodder_
Posted 10 June 2006 - 09:02 AM
I assume you mean granite? Well not usually "replaced", you see, the stonemasons use sand to blast the lettering into the stone, and the sand eventually breaks down into smaller pieces and hasnt got the strength to etch the very hard stone, so they on-sell their sand which is now about 90% granite to other users. They blast in a booth and re-use it over and over again. My brother is a stonemason and thats what he used to do.they replaced sand with crushed garnet
One worth looking at is plastic media blasting. No heat to warp panels and it doesnt allow the metal to rust as quickly as sand does as it seems to leave some sort of film on it, which is easily removed with prepsol which you'll need to do regadless of which method you use before priming.
#15 _munro_
Posted 10 June 2006 - 12:05 PM
#16 _Oldn64_
Posted 10 June 2006 - 02:50 PM
