SLR REAR SPOILER BOLT HOLE LOCATION ? PLASTIC SPOILER
19 replies to this topic
#1 LS1LX
LS1LX
  • 1,931 posts
Posted 23 September 2012 - 11:14 AM
Do the rare spares plastic rear spoilers replace the original genuine spoilers in same bolt hole locations or do I need to weld up and redrill my bootlid?
#2 _wombat_
_wombat_
Posted 24 September 2012 - 08:54 AM
i got one and the bolts are like a 1/16th out so i will have to file a bit out to get it on.
and it comes with nuts for the studs but no bolts and the threads in the holes are
just plastic no steel insert like the original
#3 LS1LX
LS1LX
  • 1,931 posts
Posted 24 September 2012 - 11:03 AM
Do the plastic threads look like they will strip once tightened?
#4 _wombat_
_wombat_
Posted 25 September 2012 - 02:32 AM
i am hoping not,but i havnt fitted it yet.think just nipping up with loctite might be the go.
#5 LS1LX
LS1LX
  • 1,931 posts
Posted 25 September 2012 - 10:30 AM
Ordered one anyway so fingers crossed, thanks for your help
#6 _Edan_
_Edan_
Posted 27 September 2012 - 01:25 PM
The H1232 Rear Spoiler we have available was moulded from a genuine LH Sedan Spoiler. The three studs and three tapped thread locations should be as per original, we worked with a Torana restorer here to have the product test fitted to a car during the development process. It also has the same style of reinforcement structure as the genuine internally in the form of three braces.
We currently only package washers and nuts with this item, I'll investigate the kitting to see if we can improve it for future stock.
-Edan Miller
Edited by Edan, 27 September 2012 - 01:26 PM.
#7 LS1LX
LS1LX
  • 1,931 posts
Posted 05 October 2012 - 01:12 PM
-Edan Miller
I found it to be slightly out as well, no big deal though
#8 _victor_
_victor_
Posted 11 May 2014 - 03:06 PM
Here are pic of my rear spoiler off my 1977 SL/R 5000. Can anyone tell me if the rare spares H1232 LH sedan spoiler mounts the same as mine?
Thanks Victor
Thanks Victor
#9 _Red One_
_Red One_
Posted 13 May 2014 - 10:17 PM
Thanks Victor
Thanks Victor
Mmmmm Yummy Plummy. Is the sealant around the mounting holes how it came from the factory? After removing my original boot spoiler and seeing the rust that had developed from the water that had run in through the holes I thought "why didnt they seal the holes?"
#10 _victor_
_victor_
Posted 13 May 2014 - 11:34 PM
Yes it looks like the same stuff that they used to stick the scuttle panel And heater box with.
First time off car
#11 REDA9X
REDA9X
    Removed
  • Inactive
  • Pip
  • 0 posts
Posted 14 May 2014 - 10:32 AM
Yes it's correct, just like the messy silver around the boot lock is 100% correct
#12 _Red One_
_Red One_
Posted 18 May 2014 - 10:21 PM
Very good info thanks guys.
First time off car
Edited by Red One, 18 May 2014 - 10:21 PM.
#13 Statler
  • 6,326 posts
Posted 18 May 2014 - 10:28 PM
They weren't supposed to last this long. :)
#14 _Red One_
_Red One_
Posted 19 May 2014 - 07:58 PM
Haha, if only they knew.
#15 _victor_
_victor_
Posted 19 May 2014 - 08:58 PM
Hi all
Who made the spoilers for Holden ? I once work at a company which assembled parts for holden, Ford and Toyota. When they moved thousands of parts went into the bin. I got a few things like injector plugs no wire on them and the boots a couple of hundred sitting in a box. Had no real need for them , thought it was a waste to put them in the bin. Could have filled a double garage to the roof with stuff. Even got 20 or so hand brake covers for a Ford Falcon from ten years ago.
Victor
#16 kiwilx
kiwilx
  • 47 posts
  • Name:Liam
  • Car:LX Sedan
Posted 26 May 2014 - 03:55 PM
Hi All
Just fitting a H1232 to my Torana and we are trying to figure out what the threads are on spoiler.  We have figured the rods on the back are metric but can't figure what they are on the boot lid.  The rest of the car is imperial but is this metric due to being aftermarket?  I know it was a while ago looking at the posts but I was wondering how you guys that have fitted one got on?
#17 _victor_
_victor_
Posted 26 May 2014 - 04:35 PM
Hi kiwilx
Are you fitting it to original boot or drilling all the holes? Try giving rare's a call. They might know the size.
Victor
#18 kiwilx
kiwilx
  • 47 posts
  • Name:Liam
  • Car:LX Sedan
Posted 26 May 2014 - 09:08 PM
Hi Victor
I'm drilling new holes in my 77 SL boot, can't quite manage a real SL/R 5000 so gave myself a bit of a project instead.  Yeah I've tried Rare's but haven't had too much luck there.
#19 _victor_
_victor_
Posted 26 May 2014 - 09:28 PM
Ok try going to a shop that sell bolts they have thread Gauge To work out what it is.
Victor
#20 _Edan_
_Edan_
Posted 28 May 2014 - 08:26 AM
The studs and nuts should all be 1/4" - 20 UNC on this spoiler.
Regards,
Edan
