Indicator switch playing up
9 replies to this topic
#1 _dagsy_
_dagsy_
Posted 24 September 2012 - 02:06 PM
anyone know of a good fix with the contacts inside the indicator switch. drivers side works ok, but the passenger sideseems to be loose and the rear indicator stops working. best bit is is only does it sometimes, usually after i have pulled it all apart , works, back together then starts playing upagain....
i have though about soldering them to the posts...
what i mean
#2 _lcgtarrh_
_lcgtarrh_
Posted 24 September 2012 - 07:52 PM
G'Day
Been there, tried to fix that, never had a successful repair.
you are on the right track with soldering but I would find another, sorry to say.
You could have this apart heaps more before its right...
GW
#3 _dagsy_
_dagsy_
Posted 25 September 2012 - 11:50 AM
i thought it would be a case of replace rather than repair....then i saw the cost of a new one!!!! $160ea
#4 Hybrid
Hybrid
  • 195 posts
  • Car:LC 2 Door
Posted 05 April 2013 - 01:36 PM
It appears that these indicator switches are available both from Betta Auto Rubber ($210) and Rare Spares ($145). Is one better quality than the other? Are the Rare Spares ones reliable?
#5 Hybrid
Hybrid
  • 195 posts
  • Car:LC 2 Door
Posted 09 April 2013 - 11:40 PM
Surely someone must have bought have bought a new indicator switch for their LC from either one of these vendors???
The customer service at Rare Spares at Prospect NSW is pretty crap so I am leaning towards Betta Auto. I just want to make an informed decision....
#6 S pack
  • 15,747 posts
Posted 10 April 2013 - 12:01 AM
Looking at the pics on both suppliers sites I'd say the Rares one looks better if the pic is truly representative of the product you will be supplied.
I did see the HK/T/G LC indicator switches at Rares Virginia last year and can say that at that time the switch assy looked just like the one on the Betta site.
It was all white plastic and had the separate wires taped together and a had a bearing that was different from the original type.
However the one depicted on the Rares online shop has a black plastic body (which I assume is made of a better/stronger plastic), has the ribbon type wiring loom and now boasts an original type bearing (that actually looks like an original bearing).
Wouldn't surprise me though if these switches are all made in the same factory, from the same tooling.
Maybe talk to Tony or Andrew at Rares Virginia on (07) 3216 2600, you will be happy with the service.
#7 _LJdave_
_LJdave_
Posted 10 April 2013 - 09:06 AM
had a lot of trouble with mine flicking off when turning left
I ended up finding a good one in a HG/T/K at pick-a-part and fitted
that to my LJ no problems since, as for the repo ones you need to
hear from someone who has one
#8 GTR469
GTR469
  • 499 posts
Posted 10 April 2013 - 11:57 AM
I have fitted the rares one to my Lc, am happy with it but has only been in the car for 10 months.
#9 Hybrid
Hybrid
  • 195 posts
  • Car:LC 2 Door
Posted 11 April 2013 - 11:05 PM
Thanks guys. I'll try and pick up a Rare Spares one then. Appreciate your feedback.
#10 _blair_
_blair_
Posted 23 April 2013 - 03:07 PM
hi guys im trying to fix the same problem in my LJ torana im replacing mine. is there a trick for getting the old indicator wiring and plug out? or do you have to take the whole steering colum apart? cheers blair
