Points ignition or stick with electronic dissy
_rb3torana_
Posted 06 October 2012 - 12:49 PM
_STRAIGHTLINEMICK_
Posted 06 October 2012 - 01:07 PM
Ive recently got my turbo 202 going and have got a surge/miss in the upper rpm. No matter what timing, fuel curve, a/f ratio (from 11.0 to 12.0) etc I change it doesnt alter it. It sort of revs then pauses then revs again sometimes with a faint miss. I have been researching and found that some people run better with the points setup. Ive also read about using a plastic drive gear on the dissy? Just wondering some thoughts? Thanks
The Bosch electronic will do the job if it is in good cond with the correct advance curve.I would only change the distributor to prove a fault.The plastic drive gear should'nt affect your timing unless it is worn or damaged.Mick
Posted 07 October 2012 - 11:47 AM
Posted 07 October 2012 - 12:16 PM
This seems to cause some chatter and stray spark.
All factory holden six dizzies had a plastic gear TMK
Posted 07 October 2012 - 05:41 PM
From memory the VK service manual says its plastic so if the dissy jams...the gear breaks.
Posted 07 October 2012 - 05:42 PM
Hang on, i have two 186's sitting here pre HQ that had plastic drives on the dizzies?
_Crooner_
Posted 26 December 2012 - 07:21 PM
That was the first thing we did after balancing and blue printing. It has been a while I must say but I always though points were better at high revs
Posted 26 December 2012 - 08:06 PM
But................electronic dissys put less load on the shaft compared to twin point and acheive the same purpose.
_Emu_
Posted 26 December 2012 - 08:26 PM
Removing a Bosch electronic dizzy for a points dizzy is madness....
If it is an ignition issue then try another electronic dizzy, module, plugs, plug gaps, leads, coil.....
Posted 26 December 2012 - 08:46 PM
_oldjohnno_
Posted 26 December 2012 - 09:04 PM
Valve springs adequate for rpms & boost level?
_tryhard_
Posted 26 December 2012 - 10:14 PM
_stretchlc_
Posted 27 December 2012 - 12:04 PM
Edited by stretchlc, 27 December 2012 - 12:09 PM.
