Clutch and pressure plate to suit Saginaw 4 speed
_LHSL308_
Posted 17 October 2012 - 07:23 PM
Posted 17 October 2012 - 07:52 PM
_LHSL308_
Posted 17 October 2012 - 08:58 PM
Edited by Gonedeaf, 17 October 2012 - 08:59 PM.
Posted 17 October 2012 - 09:23 PM
Posted 17 October 2012 - 10:08 PM
_LHSL308_
Posted 18 October 2012 - 05:09 AM
I can find out but im pretty sure im running a one tonner clutch and pressure plate on my sag box
Thanks Gene. I want something heavy duty anyway as gonna be throwing out between 350-400HP.
Posted 18 October 2012 - 08:18 AM
Posted 18 October 2012 - 12:00 PM
Jim Berry Race clutches 07 38479999
I use a ceramic/metalic wot ever 6 button clutch & pressure plate of his & its brilliant. I drives like an organic clutch
So much better than the 2 Exteme(ly shit) clutches before!!
I have 403rwhp 550ft/lb estimated flywheel torque, has done many runs down the strip & have smoked it in 1st , 2nd & 3rd (gets really silly after that) with no slip or issues
I certainly recommend giving him a call. Just dont do it on a mobile unless you got it plugged into the power!
_LHSL308_
Posted 20 October 2012 - 05:52 PM
Sounds expensive not to mention the postage for something this heavy. Really just after a heavy duty clutch and pressure plate locally, part number would be handy as well.
Posted 20 October 2012 - 07:29 PM
Posted 20 October 2012 - 08:20 PM
The one tonner pressure plate has higher clamping pressure
No wonder my clutch is hard to depress
Posted 20 October 2012 - 08:54 PM
Be careful of the poor old Saginaw with that much hp! They like to fall to bits with a factory rated 250hp 327 or 300hp 350 and skinny tyres!
_LHSL308_
Posted 20 October 2012 - 10:41 PM
Yeah I think we have talked about this in the past. I would like to change it to a muncie but the cost of the rebuild engine and removal has already broke the budget(misses haha). Would like to change it in a few years if still have the interest in the car.
Posted 21 October 2012 - 07:57 AM
_ht467_
Posted 21 October 2012 - 08:20 AM
http://www.sunburybrakes.com.au/
Good info, prompt service and good price.
Regards Jeff
_LHSL308_
Posted 21 October 2012 - 09:36 AM
_LHSL308_
Posted 26 October 2012 - 02:08 PM
http://www.sunburybr...om.au/prod2.htm
Posted 26 October 2012 - 02:58 PM
_LHSL308_
Posted 27 October 2012 - 11:43 AM
Posted 01 July 2014 - 05:14 PM
I had been going around in circles trying to sort out clutch issues with my Group C commodore. Stumbled onto the guys at Sunbury Brake & Clutch and they were great.
Regards Jeff
How is their product?
I notice they have a Supra to Holden V8 kit.
s
#21
_LHSL308_
Posted 01 July 2014 - 06:08 PM
No complaints about the clutch it works perfectly. The only problem I've had is with the throwout bearing I bought from them. I need to replace it at some stage as it was making some squealing noises occasionally. It hasn't done it for ages but it will be changed when the gearbox comes out to fix a slight oil leak.
#22
_LS1 Taxi_
Posted 01 July 2014 - 06:52 PM
s
Hi s,
I've used their Supra to Holden v8 kit in the past.
Worked fine and is all painted a shiny green colour
#23
Posted 01 July 2014 - 07:00 PM
Thanks, will definitely keep them in mind should the clutch need replacing.
s
#24
_LHSL308_
Posted 01 July 2014 - 08:30 PM
