I had some after market steering wheel on when i purchased the gherkin and have now got a ridgy wheel and bought a rare spares horn button. The question is, does the black wire hanging out suppose to conect to the back of the alloy centre badge. i cant see any other place to put it. If anybody has a diagram of how to put a new complete button setup on it would be much appreciated. Thanks for taking the time to read this querie.
LC horn
_andre_
, Oct 26 2012 05:47 PM
4 replies to this topic
_andre_
Posted 26 October 2012 - 05:47 PM
_stretchlc_
Posted 28 October 2012 - 09:22 AM
Thats correct!...when you push on the horn pad it completes the circuit and the horn sounds...should have a male spade terminal there for the female wire connector!
Posted 28 October 2012 - 10:12 AM
The black wire , which is connected to the indicator assy wiring connector should have a bronze pin approx 7/8" long, a spring and a black plastic retainer on the end. This bronze pin installs into the tubular protrusion in the steering column upper bearing/indicator switch housing and contacts the horn ring that attaches to the underside of the steering wheel boss.
Not the best view of the LC switch assy but you can see where the black wire goes.
http://www.rarespare...product=7430631
Assuming the Rares repro LC GTR horn button/cap is the same as the genuine item, the back of the cap should have two adjustable fully threaded pins with lock nuts. These pins make contact with the two male spade contacts in the horn ring when you push on the horn button.
Edited by S pack, 28 October 2012 - 10:13 AM.
Posted 28 October 2012 - 10:51 AM
Ahhh, think I've got your problem now. The aftermarket steering wheel had a black wire that connected to the spade on the horn ring, came up through a hole in the boss and connected to a spade on the back of the horn button.
If this is the wire you're talking about then pull it off, you don't want it there.
This is again assuming the Rares repro LC GTR horn button/cap is the same as the genuine.
_stretchlc_
Posted 28 October 2012 - 10:54 AM
I've been working on wayyyyyyy too many Japanese Cars lately!!...............Dis-regard my ramblings, Dave's info is correct!.......(stretch slinks off to consider fitting his GTR steering wheel now)
