LJ Dual Scale Speedo Odometers
Is your odom miles or KM
33 replies to this topic
#1 S pack
  • 15,745 posts
Posted 01 December 2012 - 08:28 AM
Mike 73 purports the odometer in the LJ dual scale speedometers (original manufacture type, not one with a conversion decal) records the distance travelled in miles and I believe it to be km's.
Question to all members with an original LJ or HQ dual scale speedo. Does your odometer accord with miles or km?
Dave.
#2 _sunburst73-xu1_
_sunburst73-xu1_
Posted 02 December 2012 - 06:28 AM
Dave.
Hi Dave,
Surely by now you should know that old mates just making things up to suit himself.
This is out of a June 73 LJ owners manual.
cheers Dane
Attached File  20121202_071754.jpg   38.87K   11 downloadsAttached File  20121202_071804.jpg   46.79K   6 downloads
#3 _hutch_
_hutch_
Posted 02 December 2012 - 07:14 AM
What needs to happen here is for everyone to go for a squirt in ya torrie over a 5 klm measured distance or there abouts and post the results ??? and dont forget the build date to i spose,and i know some will have replacement speedo/odometers too
Edited by hutch, 02 December 2012 - 07:15 AM.
#4 S pack
  • 15,745 posts
Posted 02 December 2012 - 08:02 AM
Thanks Dane and Phillip.
The info in Danes Owners Handbook is 100% correct. All LJ and HQ dual scale speedometers have odometers that record the distance travelled in KM not miles.
The dual scale speedometer is a full metric instrument which has the primary scale graduated in kilometers with a secondary scale graduated in mph.
GMH also released full metric warning light and combined instrument clusters which had single scale KM speedos. These metric instrument panels were optional equipment in LC & LJ Torana however I doubt very many, if any, new LCTorana owners would have optioned the metric only instruments.
Two GMH documents, one dated April 1973 and one dated August 1973 confirm the odometer reading is in KM.
I'll put up some pics soon.
Dave.
Edited by S pack, 02 December 2012 - 08:03 AM.
#5 S pack
  • 15,745 posts
Posted 02 December 2012 - 09:01 AM
In the 'XU1 Replacement and HQ Block Changes' thread in the 'Engine' forum, Mike 73 made this wild claim about LJ dual scale speedometers. Being the anal type of person that I am I just couldn't let this go unanswered.
Mike 73 wrote.
The odometer has only 6 windows and one of those was in parts of a mile, it would have taken a total redesign of the odometer and a change of the gearing to be able to read more than 99999 Km, no such redesign occurred. The Monaro would have been in the same boat as was the HJ model as I recall?
I have owned LC, LJ and TA of these models for 35 years cocsesecutively now and have wrecked many more from years 1969 to 1975 and none of these had a metric odometer, it was not possible to fit an extra numeral window in the odometer.
I believe the speedometer facia did change slightly in the later 70's as a spare part, and there were also vinal stickers available but these were not produced past 1977, though they are being produced again now. These stickers are marked with miles at the bottom.
The speedo came in both 100 mph and 120 mph versions, which changed to a dual reading ( miles inside and Kms on the outside ) for the speedo 100mph about July 1973 and a dual reading ( miles inside and Kms on the outside ) for the XU-1 about August 73 neither of these were metric odometers and none manufactured after these dates had metric odometers.
No good looking at a parts book because these were not even printed until 1975 when several changes had occurred to spare parts anyway.
There were several versions of the instrument pannel too ( none with double handbrake lights )
Mike
Now here is the proof.
On the left is a dual scale 160 kph speedo and on the right is a 100mph speedo.
Note the different odometer drive transfer shaft gears.
On the left is the 160kph speedo gear (12 teeth) and on the right is the 100mph gear (10 teeth)
A practical test of both odometers (number of drive cable turns to move the 10th of a km/mile digit from 0 to 1) gave the following results:-
160km/100mph speedo = 66 turns.
100mph spedo = 105 turns
One kilometre is equal to 5/8 of one mile.
105 turns divided by 8 =13.125 x 5 = 65.625 (66) turns.
Conclusion: The dual scale speedo has an odometer that records distance travelled in KM.
This is the 200kmh full metric speedo Part No. VS11190. This speedo was available in a full metric instrument panel as an option in the LC Torana.
#6 Kockum
Kockum
  • 478 posts
Posted 02 December 2012 - 09:11 AM
Just checked my cars P/N 9933220 LJ guardian maintenance owner booklet dated 6/73 .
For 20 dealer service boxes to be filled in at time of service there is both MILES or KM to be recorded .
My cars dual scale speedo is dated 7/73 .
#7 S pack
  • 15,745 posts
Posted 02 December 2012 - 09:15 AM
BTW Mike, there was not set introduction date for the metric system in Australia, it happened gradually over a long period of time.
Road speed signs were changed nationally to metric over a one month period in July 1974 however no ADR's regarding speedometers and odometers existed until 1988. Vehicle manufacturers were free to use whichever type (km or MPH) up until 1988.
As I said to you in another post: I recommend you do more research.
#8 S pack
  • 15,745 posts
Posted 02 December 2012 - 09:20 AM
That would be correct, the dual scale speedo was introduced into production for LJ & HQ in July 1973.
The original introduction date was slated for March 1973 but for whatever reason it was postponed until July.
#9 meanmachine72
meanmachine72
  • 2,045 posts
  • Name:Jono
Posted 02 December 2012 - 12:09 PM
another mike llub tihs story put to bed...that new book must bad if he had any thing to do with it, and well done dave for showing the goose up again... he got no idea and makes things up tp suit his own twisted agenda...put some pics of ya rust out shell mike. been told you moved the shell without the jig and car split in half..pics of that would be great..pity i turn your tag details to red = dead
#10 Kockum
Kockum
  • 478 posts
Posted 02 December 2012 - 01:06 PM
Holden knew metric speedometers were on the way in December 1972 - possibly earlier .
From the above dated owners manual -
Normal instrument cluster ..... SPEEDOMETER 0 - 100 MPH or 0 - 160 KM/H .
Sports instrument cluster ..... SPEEDOMETER 0 - 120 MPH or 0 - 200 KM/H .
#11 S pack
  • 15,745 posts
Posted 02 December 2012 - 01:14 PM
I read that a major Australian car manufacturer made a commitment back in 1968 to change over to metric instruments, apparently this was before the Aust Govt had made a decision about officially adopting the metric system.
Might have been GMH or could have been Ford. :dontknow:
Edited by S pack, 02 December 2012 - 01:15 PM.
#12 _Ozzie Picker_
_Ozzie Picker_
Posted 02 December 2012 - 02:06 PM
Thanks Dave,
Very interesting and detailed account .
Nothing like that scattered retards hands on accounts.Checking oil level is about as far as it goes.
#13 _LONA-CK_
_LONA-CK_
Posted 02 December 2012 - 02:41 PM
he along with a number of other not so old forum members are the reason why those that do know a bit about these cars and the history dont have much to say any more, its one thing to answer a question but its anther think to be told you dont knoiw what your talking about,,, at the end of the day it all HEHAHEHAHA
i get alot of questions asked of me by pm and when the answer is given the some still want to argue the point, honestly i cant be bothered.
have fun fellars
cheers gong
#14 Bazza
Bazza
    ǝɹnʇxıɟ ɯnɹoɟ
  • 4,295 posts
  • Car:ɐuɐɹoʇ
Posted 02 December 2012 - 04:16 PM
Hi
Not to mention that Holden were making Metric instruments for their cars sold in the export market from at least the LC.
Bazza
Edited by Bazza, 02 December 2012 - 04:17 PM.
#15 _Mike73_
_Mike73_
Posted 02 December 2012 - 06:43 PM
I hope you will not be putting that rubbish in your book?
I went into a instrument service centre in 1977 to have some instrument work done on my XU-1 instruments and was told that it was not possible to purchase the old imperial gauge facias and there were regulations against fitting many old style instruments parts.
This matches with the 1975 part number that the readers have quoted, but what were the part numbers in 1973 for the JN instruments, is the question to be answered?
To quote 1975 part numbers for speedos is pointless, and how you would find a part number for a speedo fitted in 1973 when the previous part book was 1972 JE code instruments and the 1975 parts books had several part number revisions by the time it was eventually printed, if you know of a late 1973 parts book quoting intsruments, I would be very interested to know?
Again things have to be put into date context
No good pulling apart instruments that have been serviced or exchanged for later replacement metric units at any time in the last 40 years either?
That is about as relavent as quoting after market conversion stickers saying that is how they were manufactured!
For your interest I also know of two versions of after market stick on facias 1. the original dual type type.
2 part number 2103 with miles inside coloured yellow, at the bottom it has miles, then underneath is copyright reserved. ( std HT-G conversion sticker was No 2004NS )
2( b ). second type that no longer has yellow miles on the inside but has miles and 10 miles = 16kms at the bottom, 2. b variation which just has miles printed on the bottom.
The pre 1973 type ones were often converted to metric during the servicing and it was one of these I saw at the instrument servicing centre in 1977, I remember this because I wanted a dual reading facia for my LC but this was not possible by 1977.
It was straight metric ( not dual ) or nothing.
The whole purpose of this forum as far as I knew was to learn from each other, not score points.
If the Odometres do prove to be metric then I have learned something this time, which would be a good thing, I certainally have given a great many people the benifit of my experience in the past.
Hope this helps with your confusion?
Mike
#16 S pack
  • 15,745 posts
Posted 02 December 2012 - 07:07 PM
Yeah Mike, whatever you reckon. Confused? I'm not confused about this issue.
BTW i'm not in any way referring to any stick on conversion decals that can be put onto a MPH speedo or even converting an existing odometer to KM. Oh, and I don't need to refer to a Parts Catalogue for the dual scale instrument panel part numbers, this info is contained in the two GMH documents released in 1973. Just so you know, these 1973 vintage part numbers are listed in the 1975 LJ parts catalogue.
I learn something new almost every day, if not every day.
You can learn something too if you want to or you can have a closed mind and learn nothing.
Dave.
Edited by S pack, 02 December 2012 - 07:08 PM.
#17 Kockum
Kockum
  • 478 posts
Posted 03 December 2012 - 08:26 AM
Hi
Bazza
It's true , you do learn something new every day .
#18 _Quagmire_
_Quagmire_
Posted 03 December 2012 - 09:48 AM
the day you stop learning is the day you die....so i've been told
#19 Dr Terry
Dr Terry
  • 3,334 posts
Posted 03 December 2012 - 11:55 AM
I've got a few things to add here.
1. Metric speedos have been available for Holdens since FB days. I believe they were all used for export prior to 1973. I'm not sure if it was possible to option a km speedo in an Australian delivered car before that date. I stand to be correct here, but I've never seen it as an option in Australian Holden dealership paperwork
2. Just because an odometer 'window' is only wide enough for 6 digits, doesn't mean it has to read only miles. Early HJ speedos which were purely metric had only 6 digits (5 plus a decimal) and caused problems because fleet cars (taxis etc.) quickly reached 99,999 km before resetting to zero. Most manufacturers caught on early in the piece & soon all odometers had 7 digits.
3. I saw this comment about LJs having only miles in the odometer & thought it wasn't correct, but remained silent until I checked my own low km LJ. It is a 73 LJ S which has only travelled around 60,000 km & has never had the instruments touched since new. Trust me, I checked & its odometer reads kms NOT miles. BTW Mike73 it still has its original unique to late LJ engine mounts intact.
Dr Terry
#20 _Mike73_
_Mike73_
Posted 03 December 2012 - 12:26 PM
Dr Terry
Thank you DR Terry,
thank you for checking, now I have something concrete, so I must remember it is only the early ones with the conversion stickers that will remain in miles.
I will keep this in mind when I get my three late model LJ's on the road.
Glad you still have your correct engine mounts, we haven't been able to get those here in the west since 1980, so amost zero XU-1's here have their correct engine mounts.
I was aware of the HJ not having the extra window but didn't want to muddy the water any further.
The suggestion to me above, that some Holdens had mph right through to 1988 seems rather unbelievable too, perhaps this would only apply to export Holdens, as I have never seen it on any Australian model after HQ.
Mike
#21 _Mike73_
_Mike73_
Posted 03 December 2012 - 12:36 PM
Dave.
Thanks for revealing your source, It would be really useful if a file of all those GMH release documents was available in a complete file, then things would be much clearer, it is a real pain firstly not having a a 1973 parts book printed and secondly that when they did eventually print a parts book in 1975 that two further complications occurred one was that some parts were not upgaded to the later ones, and two that some change of part numbers had occurred and this was included with no explanation that the number had changed.
Mike
#22 S pack
  • 15,745 posts
Posted 03 December 2012 - 12:52 PM
Mike
Mike, I never said some Holdens had MPH speedometers up until 1988. If you read and understand what I stated you will see I was just making a point that no ADR for speedometers existed until 1988. Manufacturers changing over to full metric speedometers and odometers that register up to 999,999.9 km appears to have been a voluntary change not a requirement of an ADR.
While we're at it can you answer this: For what reason was the brake warning light relocated to the top of the fascia in the 1973 LJ?
Edited by S pack, 03 December 2012 - 01:05 PM.
#23 S pack
  • 15,745 posts
Posted 03 December 2012 - 01:04 PM
Dr Terry
Dr Terry
Thank you for checking your LJ's odometer, it confirms what I already knew to be correct.
Dave
#24 _1973bathxu1_
_1973bathxu1_
Posted 03 December 2012 - 01:40 PM
i know why the hand brake was changed, id like mike to answer it, after all mike and his clown friends know it all about these cars,
then they will again help to write more crap in the book, and fuxx it up yet again,
just like the 2 date codes,on these xu1s and not to forget about the 20 F 3 and the 27 F 3 heads,
not to mention that these heads may have come out with as mike stated "How many of the 27F 3 heads have you seen with screw in rocker studs and guide plates?"
mike u honestly dont believe what u have stated, do u
any way im gonna wait for u to answer regarding the hand brake question
regards aldo
#25 _Ozzie Picker_
_Ozzie Picker_
Posted 03 December 2012 - 05:15 PM
That rocker studs and guide plates will be the next bending of the truth,this guy is ruining this forum for people that are new to XU1,s,they will read his crap and believe some of it unfortunately.
Maybe because he does not own a XU1,he will try to damage the XU1,s reputation, on this forum
