Braided hose fittings!( wont go on)
Braid flared out!
15 replies to this topic
#1 _76S.L.R_
_76S.L.R_
Posted 21 December 2012 - 07:44 PM
I bought the Braided hose and all the speedflow fittings to use as tranny lines on the LX, I was hoping to get the car all back together this weekend but for the Fooking life of me I cant get the braided hose to slide into the fittings!!!.
When the Auto shop cut the hose its not been cut clean enough and even when putting in one side at and angle and then pushing the other side in with a flat screwdriver( as per clip I seen on here) it still will not go in!!,GRRRRRRRRR!!!!, its driving me mad. I dont really have anything good enough here to recut the ends cleaner and I rhink it might be too short if I cut anymore off,is there some way to make it easy to get the hose in the fittings even though the braid is now flared out somewhat?.
This is the type of fitting and hose I have but cant get the fittings on!,I shoulda told the shop to peice it all together but as it was ,sent me broke as it is....
http://www.youtube.c...h?v=aDSozy6MZto
Edited by 76S.L.R, 21 December 2012 - 07:45 PM.
#2 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 21 December 2012 - 08:14 PM
If the shop cut the hose wrong, get them to replace it.
#3 _Mint_
_Mint_
Posted 21 December 2012 - 09:59 PM
yeah they can be a bitch..i've done heaps over the years an i've always done it like in that video but i wrap tape around the hose and cut it with a very thin cutting disc mounted on a bench grinder and i use CRC or WD40
there is an assembly tool called Kool Tool made for putting the collars on the hose but dont think anyone sells em in OZ
its just patience and youll get better at it
#4 _434LX_
_434LX_
Posted 21 December 2012 - 10:11 PM
Ya should have bought Aeroflow fittings and braided -6 teflon. Easiest hoses to make I have ever done.
I tape the cut point with insulation tape, cut it with a thin disc on the grinder, remove tape and bingo, ready to take fittings.
I have never had one leak yet and I have made heaps of them.
#5 _76S.L.R_
_76S.L.R_
Posted 21 December 2012 - 10:45 PM
The hose is listed on my reciept as -6 High Performance Hose.
I dont know how these guys cut the hose but its been done TERRIBLY,I was collecting these bits on Work time so was in a hurry like no tomorrow and chucked it all in my bag,I get home ant try to fit the Anodized Fittings for over and hour and gave up,I cant even get 1 on !!. I'll have to tape them and cut with a thin grinder blade as you guys suggest
This is the hose I bought,in -6
http://www.cassellma...aided-hose.html
Edited by 76S.L.R, 21 December 2012 - 10:49 PM.
#6 _Mint_
_Mint_
Posted 21 December 2012 - 11:03 PM
yes ..you can wrap the very end of the hose with insulation tape or cloth tape and cut it 10-15 mm from the end that way you wont lose much hose
#7 ls2lxhatch
  • 5,335 posts
Posted 22 December 2012 - 12:50 AM
This is one way of fitting hose ends.
You can also buy a hose assembly tool to make it easy to get the hose into the fitting.
http://www.summitrac.../parts/KTS-681/
I have seen the Koul Tools on the shelf at A1 Hi Performance in Myaree. They may be able to just put the ends on for you. Enzed should also be able to assemble the hoses.
Edited by ls2lxhatch, 22 December 2012 - 12:52 AM.
#8 V-SLR5000-P
V-SLR5000-P
  • 1,321 posts
  • Car:L34 x 2
Posted 22 December 2012 - 07:04 AM
Its a practice thing, when l first tried l thought that it was impossible too. If you have belled the end of the braid there may be no solution but to trim the hose again. You need to start the hose into the fitting square or close to square, a very fine blade screwdriver may help to poke in the last of the braid and sharp side cutters can trim off any stray strands of wire. A little oil on the inside of the hose wont hurt either. The first ones will be the hardest but once you get a few done it will become a whole lot easier.
#9 _76S.L.R_
_76S.L.R_
Posted 23 December 2012 - 09:06 AM
I put tape on an end of one and cut with a 1mm blade on a 4" grinder then wrestled it in the fitting,my cut wasnt exactly square and the male parts was really quite hard to screw on after about half way?.I'll get a professional to dp the other 3 unless a fellow Perth member can help?,its too expensive to ruin!!.
#10 _Bomber Watson_
Posted 23 December 2012 - 09:44 AM
There not exactly designed to be done with the bare hands...
As said, tape and cut it with a grinder, i find insulation tape melts so i use masking tape. I have alloy an fitting vise jaws and the alloy non scratch an spannners, but you can just use the vice an a normal spanner easilly enough.
Start with the coller for the fitting upside down in the vice, wiggle the hose in as far as you can, then pull it out, grab the line by the hose about 2" down from the collet and start spinning it while pushing down. Regrab the collet in the vice and screw the middle bit in. Pieceapiss after you have done 50 or so lol.
#11 _the gts_
_the gts_
Posted 24 December 2012 - 08:56 PM
Yep +1 for a 1mm cut off disk on a grinder after the hose is taped. Use anti-seize or similar on the threads as well.
If the steel braid is flared you may be able to use something similar to a tapered piston ring compressor to compressthe braid back into the hose end
#12 _2wild4u_
_2wild4u_
Posted 24 December 2012 - 11:46 PM
ive been doing it with a thin cut off disc for year but a coupke of weeks ago i bought the braided hose cutters, best thing i have ever bought, tha braid doesnt flare at all, and cutter worth about 80 bucks, but if you intend on doing a few it will be money well spent
#13 _V6 UC_
_V6 UC_
Posted 25 December 2012 - 01:27 AM
Im in Perth wanneroo area and can give you a hand if u like. I use a bit of silicon spray to help them go on and do them in a vice like bomber said
#14 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 10 January 2013 - 09:20 PM
just thought i would drag this thread back up, i made 4 hoses today in about 30 mins(first timer), taped, cut with a hacksaw(new blade) pop the collar on. PBR rubber grease on the barb and it slides into the hose super easy. didnt even need to use the vice. just did it by hand with a couple of spanners.
i think the PBR rubber grease works a treat
my 2 cents
#15 ls2lxhatch
  • 5,335 posts
Posted 11 January 2013 - 01:16 AM
What size hose did you make?
The smaller the hose the harder it gets. Making your first hose with -6 as the OP did was always going to be a challenge.
#16 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 11 January 2013 - 05:55 AM
-8 hose was what i was using yesterday
