enderle fuel injection hat conversions
9 replies to this topic
#1 _fitzsi_
_fitzsi_
Posted 11 January 2013 - 11:03 PM
Does anyone know what is required when converting and enderle injection hat to electronic fuel injection.I saw one at the summernatts with the fuel lines still installed that they used for vacuum for the power brakes etc.
I know you can buy the injection plate that is installed underneath the injector hat but I d like a bit more info if anyone knows what is required
#2 _Bomber Watson_
Posted 11 January 2013 - 11:09 PM
Blown or aspirated?
Streetable or race only?
ETC.....
#3 _fitzsi_
_fitzsi_
Posted 11 January 2013 - 11:51 PM
Blown or aspirated?
ETC.....
671 blower and street driven
#4 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 13 January 2013 - 09:05 AM
The Enderle hat is just a big expensive throttle body. They are designed to operate in a very basic mechanical alcohol injection setup.
I assume you want to run petrol through this system ?
I can't say I have all the answers but I'll try to help with what I know....
The hat is modified so it only flows air through the centre butterfly, effectively making it an expensive 65mm throttle body. It needs a TPS fitted and most seem to mount the injectors in a plate directly below the hat, above the blower. I have seen a couple that use a modified "bunch'o'bananas" manifold to mount the blower, using a set of injectors in the standard location, as well as 4 more in the plate above the blower (handy I guess if you are using a VN headed combo). You then need your usual engine management stuff and someone to tune it.
Bear in mind if you want to drive this setup on the street there is, as far as I know, no facility for an air cleaner.
I'm pretty sure Paul Sant at ProFlow in Sydney has done this a few times and would be the first person I'd talk to about it.
Oh, it will not be cheap.
FWIW there is a mob in NZ that make a pretty cool looking hat that fits over a Holley carb and air cleaner. Its not cheap either but it is simple and effective...... http://www.alsblower...eetcatcher.html
Hope this helps.
#5 _fitzsi_
_fitzsi_
Posted 14 January 2013 - 11:37 PM
thanks
Already have one of those bug catchers.Yes they are very nice but deffinately want to run fuel injectionas its heaps more responsive and you I can tune it with my Motec system
#6 _BLO 355_
_BLO 355_
Posted 02 February 2013 - 10:35 AM
i was just speaking to good vibrations racing ,about that looking at having injector hat ,the price on elec fuel injection plus computor then getting sombody to tune it was pretty pricey,but the mechanical set up cheaper but there is always a but low down not that good ,midrange not that good but ful noise yee haa,or stay with two carbys on top like i have they work injector hat looks good sounds good ,dont know yet
#7 _pinklx_
_pinklx_
Posted 02 February 2013 - 12:05 PM
i belive joe blo enginering makes a setup that goes inside the hat for the injectors so it still looks standerd on the outside. he has a website. google him.
#8 Tiny
Tiny
  • 10,018 posts
  • Name:Tiny
Posted 26 October 2015 - 12:53 PM
Bump of an old thread!
Joe blo racing does do this, and its something im researching now too! Any new info would be great!
#9 dattoman
Posted 26 October 2015 - 07:59 PM
Speak to Mike Chilando
He's on my stalkbook friends list
http://www.alkydigge...1GMC-H(3-5/8)EL
#10 Tiny
Tiny
  • 10,018 posts
  • Name:Tiny
Posted 26 October 2015 - 08:16 PM
Ooooo i loik that!!
Will be a little way off, reaearch now... save/win lotto THEN makenit happen!!
