He told me it came from United Motors in Adelaide. Anyone seen something like this???
Posted 27 January 2013 - 08:07 PM
Posted 27 January 2013 - 08:14 PM
Posted 27 January 2013 - 08:17 PM
Posted 30 January 2013 - 08:30 PM
Posted 31 January 2013 - 11:16 PM
Original folders are hard to come by.......
Looks to be in excellent condition.
I'd be keeping a very tight grip on that and putting it somewhere safe and clean.
Grant..
Posted 01 February 2013 - 01:05 PM
Posted 01 February 2013 - 01:21 PM
Posted 01 February 2013 - 09:44 PM
Posted 01 February 2013 - 09:53 PM
Posted 02 February 2013 - 12:16 AM
Posted 02 February 2013 - 06:48 AM
Posted 02 February 2013 - 01:43 PM
Posted 02 February 2013 - 02:30 PM
Posted 02 February 2013 - 02:34 PM
Posted 09 February 2013 - 01:29 AM
Hi
I have seen the '75 edition (green cover) of the LJ go for around $200. The earlier '72 edition (red and blue cover) goes for a bit less because it doesn't have he '73 Bathurst parts in it.
Bazza
Edited by Mike73, 09 February 2013 - 01:32 AM.
Posted 09 February 2013 - 07:39 AM
WRONGThere are mistakes and omissions in the June 1975 parts books as some carry over parts are not udated and some superseeding parts do not indicate that the part has changed.
There is no part number change for the Aug 73 carbie boddies even though these were changed,
Mike
Edited by sunburst73-xu1, 09 February 2013 - 07:40 AM.
Posted 09 February 2013 - 03:16 PM
Posted 09 February 2013 - 03:18 PM
Edited by S pack, 09 February 2013 - 03:23 PM.
Posted 09 February 2013 - 03:22 PM
At any given time it was quite permissable to use componets Holologated for use up to that point in history and this also includes the carbies, I am not going to go in depth about carbie numbers, however if you look at any published build sheet between Aug 72 and the end of production in Sept 73 you will find that there were either of two sets of carbies available for use.
I am reliably told that this consisted of the rubber fuel line ones and the steel fuel line ones, going by the parts numbers quoted.
The T226 TCX were cast Jan 1973 and yes they were fitted to 6 - 9 months cars but the statement that the changed bodies for these carbies are not reflected in the parts books still remains true and likely accounts for why so many sets are mixed up with the two types of carbie boddies.
The fact also remains that as in the build sheets if a late 72 or 73 XU-1 optioned with the earlier 949 rubber line carbies required a carbie replacement, then the 1975 parts book was wrong as no push on rubber line carbies are even listed for those cars.
Mike
