Flare bolts M8 or M6 ?
9 replies to this topic
#1 LJGTR6
LJGTR6
  • 309 posts
  • Name:Steve
  • Car:1977 LX SL 4 Door and 1973 LJ 2 Door
Posted 03 March 2013 - 06:06 AM
I just wanted to get an opinion on the flare bolt sizes people have used.
When i originally put mine on i used M6 stainless cap screws.
when i picked up my Wilson flares kits from john the kits came with
M8 cap screws.
Without seeing them on i thought straight away that the head would look big in the flare recess.
Has anyone used M8 cap screws on the wheel arch flares.
how did they look.
steve
#2 76lxhatch
  • 7,218 posts
Posted 03 March 2013 - 08:13 AM
Not speaking to originality at all, but have used 5/16" and they fit OK but didn't really like the look of them compared to the 1/4". Have gone metric now as its easier to get rivet nuts, 6mm look good to me.
#3 racean69
racean69
  • 782 posts
  • Name:Rod
  • Car:LH sedan
Posted 03 March 2013 - 08:37 AM
i have been told they were 5/16"= 8mm
#4 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 03 March 2013 - 08:48 AM
Wilson kits on all of mine
#5 a9x868
a9x868
    maurice mead of hatchbacks
  • 1,428 posts
  • Name:facebook dave
Posted 03 March 2013 - 10:02 AM
originally 5/16 unc and nutserts (hatch on all rears) front guards use nutsert on
rear double panel by the lower door hinge only and uses longer bolt
the rest are nut spring and flat washer with shorter bolts
#6 _woodsie_
_woodsie_
Posted 03 March 2013 - 10:36 AM
Interested in getting these cap screws also can you also give the length of these bolts that are required.
Chris
#7 Statler
  • 6,328 posts
Posted 03 March 2013 - 11:50 AM
I used M6 because they fit the flare better IMHO.
#8 LJGTR6
LJGTR6
  • 309 posts
  • Name:Steve
Posted 03 March 2013 - 05:15 PM
Chris
Chris.
My guess is that if they were 5/16 originally then the ones i had given to me from john were probably 5/16 x 1/2 (M8 x 12mm)
some of them will have to be shortened in certain areas.
Seems a mixed bag of opinions there. surprised me they were 5/16 originally.
i will have to check out some close up pics to see what i like.
I know what the 1/4 (6mm) look like so will have to search for some close ups of the 5./16.
Thanks for the feedback.
much appreciated.
steve
#9 a9x868
a9x868
  • 1,428 posts
Posted 03 March 2013 - 05:32 PM
Chris
sp2572  5/16 unc x1in long cap screw by lower door hinge
sp2571 5/16 unc x5/8 all the rest
sp2343 nutsert to suit 5/16 unc
flat washer under cap screw head is 9419275
spring washer 120214
nut 120376
#10 _woodsie_
_woodsie_
Posted 04 March 2013 - 08:45 PM
Thanks Dave and Steve, appreciate the feedback.
