Help, Any pics & info of un-flared LH-LX mini & full tubs.
Posted 06 March 2013 - 11:15 PM
... instead I ended up getting married in November which made me broke, then in December I blew the 253 in my HX daily & instead of rebuilding it or putting in a reco I ended up putting a LS1 & T56 in it which REALLY made me broke....
.... So anyway, now I want to start focusing back on the torana again & get it going. But first I got to finish off the rear end & get a diff built. I want to use a diff fuel tank so I want to cut the boot floor out & delete the spare wheel well while I'm at it.
I don't want to go to a rear chassis clip because I'm unsure whether it'l be able to pass RWC, plus I don't want to spend a truck load or go ladder bar rear end etc...
Pretty much I just want to get some ideas & pics on what others have done & what would be the best solution. Ideally I want to get the biggest tire possible under it, say 265-295 so I'm hoping just mini tubbing it will be the easiest/cheapest option. The car will have around 450-500rwhp & mostly see the strip with the occational weekend cruise & drive through bottl'o run.
Cheers, Nig.
_AGGRSV_
Posted 10 March 2013 - 07:24 PM
14 inch wheel tubs, wheels are 20x10.
Four linked rear end. Fully engineered as a four seater too.
Edited by AGGRSV, 10 March 2013 - 07:28 PM.
Posted 13 March 2013 - 11:06 AM
_AGGRSV_
Posted 16 March 2013 - 04:42 PM
Lol. Sorry mate. Triangular four link underneath with chassis connectors. Deleted spare wheel well. Ended up replacing the whole rear floor section but i haven't got updated pics as yet. Hope that helped a bit..
Posted 16 March 2013 - 07:56 PM
There is a bit of info and some pics in my build thread of how I tackled it. I use 275/60R15's but would be able to fit a 295 easily.
About halfway down this page is where I cut out the wheel tubs.
http://www.gmh-toran...-project/page-2
Posted 16 March 2013 - 10:39 PM
Yeah thanks 4 that guys, appreciate it.
I thought as soon as you "touched" any part of the rail it was a big fat NO-NO & then it was un-registable?
My torana prob won't ever pass a rwc but it be close, but if I chopped the rails it be the nail in the coffin so to speak.
Posted 17 March 2013 - 08:03 PM
I have seen a couple where they have folded up their own rail sections and replaced the stockers further inboard.
Looked standard if you didn't know what you were looking at.
The rail behind the diff is the real restriction to wider tyres, you really have no option but to move it.
Posted 18 March 2013 - 06:00 PM
Posted 19 March 2013 - 08:26 AM
The tyre will hit the rail well before it hits the shock.
Cut the shroud off the shock and beat the rail a bit and you could get a 245 in there.
Posted 19 March 2013 - 05:27 PM
& Anyone thought of swapping the rails over left to right so they bend opposite & come to the middle of the boot? Just thinking outside the box.... quite possibly a little too far outside the box....
Posted 19 March 2013 - 06:35 PM
_LXSS350_
Posted 19 March 2013 - 09:04 PM
Might help?
Posted 20 March 2013 - 07:30 AM
G'day mate, that looks awesome!!! How bad do you wish they did that from the factory!!!I've moved the rails behind the wheel. More photos here http://www.gmh-toran...30-turbo/page-2
With the engineering side of things did they even pick that? It looks stock.
& how big of a rim & tire have you got under there?
Edited by WA1TNC, 20 March 2013 - 07:32 AM.
Posted 20 March 2013 - 08:37 PM
The engineer was happy with what i had done, at the moment i run 245/60 14 BFG's on 14"x7" rims and and 235/60 15 MT streets on 15"x7". With the right off set rim you could fit a 265 but that would also depend on what size rim was used.
I also done this to my other torana, you can see the problem with just moving the rail at the back the tyre starts hitting on everything else.
Edited by turbo76lx, 20 March 2013 - 08:49 PM.
_ryan350_
Posted 08 May 2013 - 02:00 PM
just to clarify, im minitubbing mine to the rail and cutting out most of the coil spring pocket out as im running coil overs, plan is to run 15x8.5" rim with 3 3/8" backspace and wanted to run a 275/50/15 tyre. As im not planning on moving the rear rails inboard can anyone see this combo working?? if i have i would settle for a 255 or 265 tyre, cheers ryan
