LX Sedan diff conversion help
25 replies to this topic
#1 _JChantrey_
_JChantrey_
Posted 26 March 2013 - 09:42 PM
I am 18. My first car, a 77 LX Torana Sedan, which is running a rather worked 202, seems to be going through my banjo single spinner diffs like theres no tomorrow.
I would like some help and information on a cheap, yet reliable diff conversion that isn't going to blow a massive hole in my pocket. As the police force is doing that for me as of late.
Obviously anything is stronger than a bango. The option of easy/cheap LSD centers would be an absolute bonus.
Thanks.
#2 Ice
  • 15,212 posts
Posted 26 March 2013 - 10:10 PM
There os no such thing as a cheap conversion on a torana lsd bango might be a bit stronger but ease up on the clutch and go pedal and you might not blow so many bangos
#3 _JChantrey_
_JChantrey_
Posted 26 March 2013 - 10:17 PM
Well perhaps i should have worded it as *Cheaper* then forking out $3000 for a 9inch conversion
Perhaps i should have worded it *cheaper* option, other then forking out $3000 for a 9inch conversion.
Also... why is this in 'Engine'. Can someone please move this to Driveline. Thanks
#4 dattoman
Posted 26 March 2013 - 10:19 PM
Its in engine cause you put it there :)
But I've moved it
Cheapest is keep fixing the banjo
2nd best is BW out of a Skyline (right width) and have the mounts changed and axles sorted
#5 _JChantrey_
_JChantrey_
Posted 26 March 2013 - 10:21 PM
Thankyou.
Maybe... More efficient is the best word? haha
As in R31 diff?
#6 dattoman
Posted 26 March 2013 - 10:32 PM
http://www.gmh-toran...e-bw-78-to-lhx/
#7 _2_many_torries... never!_
Posted 27 March 2013 - 01:39 PM
2** series volvo diff.   torana stud pattern and approx 50mm narrower than standard. cut the mounts off your torana diff and weld them on the volvo.
Gives you disc brakes too.
#8 _JChantrey_
_JChantrey_
Posted 27 March 2013 - 10:53 PM
Which is easier to find LSD centres for in decent ratios? R31 or Volvo?
#9 dattoman
Posted 28 March 2013 - 12:28 AM
R31 .. .which shares the same centre as every commodore from VL-VS
Almost every Falcon from EA-BA
And a few other makes too
#10 _JChantrey_
_JChantrey_
Posted 28 March 2013 - 08:34 AM
Alright sweet thanks. Now I've just gotta find an r31 diff...
#11 _Yella-5000_
_Yella-5000_
Posted 28 March 2013 - 04:32 PM
Borg Warner, even cut down is going to cost you just under $2k.
#12 _Growler_
_Growler_
Posted 28 March 2013 - 05:33 PM
I didnt think you needed to cut it down if it came from a r31, just change the stud pattern and mounts?
#13 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 28 March 2013 - 08:10 PM
Use a standard width VN diff and bolt on some flares.
#14 _JChantrey_
_JChantrey_
Posted 28 March 2013 - 10:45 PM
R31 is about 10mm wider each side?
I have spacers on each side so I could just take them off if it isn't sitting right.
Already have flares and the wheels site close
#15 _LH8VD69_
_LH8VD69_
Posted 20 April 2013 - 12:43 AM
I tell ya what those Volvo diffs and up for wrecking are everywhere too. I'd be inclined to go the Volvo option
#16 _JChantrey_
_JChantrey_
Posted 21 April 2013 - 06:25 PM
How much would i be looking at on average to pay to have my banjo diff mounts welded on to an R31 diff?
#17 N/A-PWR
  • 9,639 posts
Posted 21 April 2013 - 06:58 PM
JChantrey wrote in Chat
I want to cut the banjo mounts off and get them re-welded on to an R31 diff
This is a suggestion and others may be better at doing this the right way,
measure all the mountings from a Datum point on the original and transfer them to the other, tack the mountings in place and get a professional welder to fully weld them - make sure it is welded at opposite ends to keep the heat down. Dave I
p.s. IMO a standard Torana rear end with a Banjo LSD and 7" tyres works a treat
Edited by TORYPOWER, 21 April 2013 - 07:11 PM.
#18 _JChantrey_
_JChantrey_
Posted 21 April 2013 - 08:13 PM
The thin is... In the long run it will work out cheaper for the R31 conversion then sourcing a banjo LSD, getting it rebuilt. Rebuilding every time it wears and then upgrading diffs anyway when i go down the V8 path
#19 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 21 April 2013 - 08:25 PM
Aren't the banjo LSD clutch packs near impossible to get now?
#20 _JChantrey_
_JChantrey_
Posted 25 April 2013 - 02:01 AM
Yes they are
#21 rexy
rexy
  • 3,758 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 25 April 2013 - 12:17 PM
Just sold my spare good nine inch for lh lx. Got $1500 for it.
I'd be looking for a good secondhand nine inch if I was you.
#22 _JChantrey_
_JChantrey_
Posted 25 April 2013 - 06:50 PM
Was that ready to bolt in and use?
#23 ls2lxhatch
  • 5,335 posts
Posted 25 April 2013 - 10:46 PM
The BW78 and banjo LSD does not use clutch packs. The banjo and BW78 LSD use a steel cone which will not last anywhere near as long as a clutch pack LSD.
If you want traction from a BW78 then you would need to fit either a Lokka or a KAAZ.
#24 Rob2408
Rob2408
  • 309 posts
  • Name:Rob
  • Car:1974 L32 SLR
Posted 26 April 2013 - 09:36 PM
Traction, who's looking for traction.....am i missing the point  :blink:
#25 rexy
rexy
  • 3,758 posts
  • Name:Rexy
Posted 27 April 2013 - 02:00 PM
Yep. Complete including orig brakes and handbrake cables.
