3 on the tree selecting gear issues
3 replies to this topic
#1 _chanoo_
_chanoo_
Posted 11 April 2013 - 07:23 PM
Hi fella's,
I have lh with a 202 it's got 3 on the tree and its having issues. I can select 2nd and 3rd however when I want either 1st or reverse, I pull the gear stick towards me and nothing it still selects 2nd or 3rd. Under the bonnet I can move the gear linkages by hand and select 1st and reverse no worries. It s just not being selected via the gear stick.
Has anyone had this issue before and found a fix? Also is it a common issue with column shifts
Any ideas because I don't have any
Chanoo
#2 76lxhatch
  • 7,218 posts
Posted 11 April 2013 - 08:46 PM
It switches between 1st/reverse and 2/3 in the column at the inner end of the shifter, that's where you need to look
#3 rodomo
  • 18,055 posts
Posted 11 April 2013 - 08:50 PM
You might have broken the knob off the end of your stick?
Or maybe your knob has fallen out of it's hole? :dontknow:
#4 _chanoo_
_chanoo_
Posted 11 April 2013 - 08:59 PM
Thanks for replies,
Rodomo had a good look at he gear stick and its till,n the correct position
76 LX I thought this may be the problem at the inner end of the shifter, can this part be changed or is it better to source a whole new column
Ta Chanoo
