alloy fuel cell in LJ Torana
8 replies to this topic
#1 _nostolgia186turbo_
_nostolgia186turbo_
Posted 14 May 2013 - 12:25 PM
ok , went to put my fuel tank back in my lj torana & as i was cleaning it i found at least 8 holes withing a 10 inch area - so i gave up . lol . SO i know fuel cell are ILLEGAL - BUT only because the inlet is in the boot - not fillable from outside - SO im thinking why cant i use the original filler area & run a pipe to the tank - as factory . IM looking at a 60 litre alloy fuel cell that also has a fuel sender installed . maybe i could get a welding shop to weld a inlet pipe onto the cell ?. ANY idea,s on this would be appreciated . thanks OR maybe someone here has a GOOD factory tank they can sell me .
#2 N/A-PWR
  • 9,642 posts
Posted 14 May 2013 - 12:50 PM
Hi nostolgia186turbo,
Here is an XU1 17 gallon / 77.3 litre Tank for 395 bucks:-
http://www.ebay.com....W-/230924918418
#3 _stretchlc_
_stretchlc_
Posted 14 May 2013 - 01:03 PM
See if you can hunt down an old Price Engineering Alloy Tank.............these bolt straight in, have a filler neck spout welded into the tank that connects straight to the factory hose/filler inlet. Bigger capacity tank too, looks a lot like an alloy drop tank from the back, but with the same capacity as an xu-1 tank and is a similar design to the xu1 tanks.
#4 Stinga
Stinga
  • 2,114 posts
  • Name:Stinga
Posted 14 May 2013 - 02:42 PM
was it marty that pulled one of these out of his car??
#5 warrenm
warrenm
  • 2,129 posts
  • Car:1972 LJ Torana
Posted 14 May 2013 - 02:58 PM
Depending on the holes you could coat the tank with a POR15 or KBS coatings product, I repaired my LJ tank several years ago using the KBS product.
#6 _nostolgia186turbo_
_nostolgia186turbo_
Posted 14 May 2013 - 06:13 PM
yer holes are pin holes & from what ive seen so far i reckon there will be way too many to bother repairing .. did not really want or see the need for a xu1 tank as its a 4 door .. thats why i thought a CHEAPER alloy cell would work just as good .
#7 _stretchlc_
_stretchlc_
Posted 14 May 2013 - 06:25 PM
I had a Price Engineering Alloy Tank in my car at one stage.....that is, until I put back a standard tank into it because I had the bottom modified to take a welded in baffle to accept a braided line.....I'll try and dig up a few pics of it.
#8 _stretchlc_
_stretchlc_
Posted 14 May 2013 - 06:32 PM
Attached File  20008_384632788290694_1719537824_n.jpg   53.08K   5 downloadsAttached File  46154_384632224957417_749677551_n.jpg   57.62K   3 downloadsAttached File  312447_384631651624141_920970157_n.jpg   56.83K   1 downloadsAttached File  321011_384632691624037_852550006_n.jpg   60.09K   1 downloads.
#9 _Bomber Watson_
Posted 14 May 2013 - 08:49 PM
+2 for the KBS tank sealer.....If there only pin holes and you follow the instrctions you will have a new tank :D
