key not returning
VZ ignition
6 replies to this topic
#1 lakeside
lakeside
  • 2,703 posts
  • Car:LC SBC
Posted 16 May 2013 - 11:28 PM
The ignition key doesn't spring return after you start. I replace the key barrel about 4mths ago because it jammed.
#2 TOERUNNER
TOERUNNER
  • 630 posts
  • Name:RODNEY
  • Car:73 lj gtr 73 lj 2 dr S
Posted 17 May 2013 - 03:46 AM
possibly ignition switch
#3 S pack
  • 15,746 posts
Posted 17 May 2013 - 09:34 AM
^^^ Agree, most likely the problem lies in the ignition switch not the lock barrel.
#4 derrin71
derrin71
  • 494 posts
  • Name:Derrin
Posted 17 May 2013 - 03:54 PM
The ignition switch is further down the column it is attached to the key barrel by a wire rod.  It is made out of white plastic with various wires plugged into it. The return spring is inside this switch.
#5 Tyre biter
Tyre biter
  • 982 posts
  • Car:Should have gone with Palais...
Posted 29 May 2013 - 10:01 PM
I had this problem when putting my column back together.
Turns out the ignition switch that attaches with a wire rod inside the coffee pot that Derrin talks about is a rectangle type thing which is has silver coloured  metal on one side and beige plastic in the other with a sheathed set of ignition wiring attached.
This whole thing attaches to the column with two small bolts.
The switch has elongated holes to allow the switch to be adjustable.
Like your ignition, mine wasn't springing back as it should after being turned to start, but loosening the bolts and moving the ignition module down the shaft a little before re-tightening them cured this.
Hope this helps.
Cheers, TB
Edited by Tyre biter, 29 May 2013 - 10:02 PM.
#6 S pack
  • 15,746 posts
Posted 29 May 2013 - 10:07 PM
Hey Guys, I could be wrong but I think his problem is with a VZ Commodore ignition switch not a Torana.
#7 Tyre biter
Tyre biter
  • 982 posts
Posted 30 May 2013 - 09:51 PM
Oops... sorry about that.
Maybe OP should try www.ls1.com.au then?
Cheers, TB
