testing a coil
6 replies to this topic
#1 _steve253_
_steve253_
Posted 02 June 2013 - 08:40 AM
How do I test a coil to see if its working. Cheers
#2 robd74
robd74
  • 89 posts
  • Name:Ben
  • Car:LC 2 Door & LX SL/R
Posted 02 June 2013 - 10:33 AM
Best to test in a car to see if there are no high voltage breakdown issues, as using a multimeter will only be testing at about 9v.  However, with a multimeter on ohms you can check the resistance between the side terminals of the coil (+ and -). Do this with all of the wires to the coil disconnected.  You should see 1.4 Ohms (ballast resistor GT40R) to 3.4 Ohm (non ballast resister GT40).
Then check the resistance between either side terminal and the center high tension terminal. The reading should be 3,500 to 11,000 ohms, but this is not a great test as there could be a short to earth that the multimeter is not able to find.  Best to check the secondary side in the car.
#3 _steve253_
_steve253_
Posted 02 June 2013 - 10:40 AM
sorry should of said its an electronic ingnition
#4 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 03 June 2013 - 09:31 PM
Best to check it outside at night with the bonnet nearly closed. The extra darkness will make it easier to check for stray sparks.
#5 TerrA LX
Posted 04 June 2013 - 10:27 AM
This is the best way to check a coil, works on any coil tho the numbers may vary, it is usually easy enough to google the correct figures with a part number etc.
IF you don't have an ohm meter you could buy a cheap spark plug tester and wire the coil up to a car and test for a good clean bright blue spark.
#6 r2160
r2160
  • 712 posts
  • Name:Glenn
  • Car:2/71 LC GTR, 4/71 LC 4 'S'
Posted 04 June 2013 - 12:53 PM
Best way to check it is to connect the positive and negative terminals to a battery for a couple of seconds and put your tongue over the terminals.
If you wake up 10 minutes later, its OK ;)
Glenn
#7 hanra
  • 11,013 posts
Posted 04 June 2013 - 01:02 PM
An ignition coil will not store a charge in the same way a capacitor will.
