door pin removal tool
12 replies to this topic
#1 shanegtr
shanegtr
  • 533 posts
  • Name:Shane
  • Car:LJ 2 door
Posted 23 June 2006 - 10:54 PM
Would this be able to do the job and is the price ok
http://cgi.ebay.com....1QQcmdZViewItem
Bear in mind that I have very limited stores up here to buy this sort of thing
#2 _LJ308injected_
_LJ308injected_
Posted 23 June 2006 - 11:08 PM
They are ok for commodore's and cheap enough but if you want 1 for a LC-LJ Torana i used a chisel and grinded in the middle the thickness of the door pin and that is just as good and cheap aswell.
Cheer's Steve
#3 shanegtr
shanegtr
  • 533 posts
  • Name:Shane
  • Car:LJ 2 door
Posted 23 June 2006 - 11:27 PM
I might have to make something up at work then :D
#4 _Yella SLuR_
_Yella SLuR_
Posted 24 June 2006 - 12:13 AM
One of the few occaisions that I had to work on an LC/LJ, I knocked the pins up with a hammer to the bottom of the hinge, then got needle nose pliers under the bit on the top that popped up, and applied the hammer to the underside of the needle nose pliers. Worked a treat, just need somebody to hold the door while you do it.
Edited by Yella SLuR, 24 June 2006 - 12:13 AM.
#5 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 24 June 2006 - 10:28 AM
I believe the commo and gemmi doors have hollow pins.
Youll have to do what^^ said, i ended up cutting the top section of the hinge off as it was rusted in, that bastard was never coming out, so i introduced it to my air saw. hehehehe :furious:
#6 marius
marius
  • 39 posts
Posted 24 June 2006 - 05:41 PM
if you can, try to keep those original door pins. bought some repro pins from rare spares and they ended up being a couple of thou too wide for the door hinges. took a lot of love to get them to fit. hammers, lube and patience...
#7 _rorym_
Posted 24 June 2006 - 09:29 PM
Heres one not so well know fact..well..it might be...Rare Spares LC/J pins are made 4 thou bigger to take up wear..or they are just slack on measuring them...dont know..but they go in about a third the way then the heads bend when you hit them..turn them down 4 thou and all is bliss.
#8 _troy_
_troy_
Posted 24 June 2006 - 10:44 PM
Angle grind an old screwdriver after smacking the pin with a\hammer and use the sawn off screw driver as a punch to knock he pin out
#9 _dave720gtr_
_dave720gtr_
Posted 26 June 2006 - 08:10 PM
yer there tuff too remove , but i think the original gmh tool is no good
to you! 30 odd years have passed there stuck rusted in. and less the original
owner oiled the hingers if your lucky :D the gmh tool tends to snap the head off the pin then you have a pin thats stuffed , heat small oxy flame and pin punch is the way to go and plenty of onox or some wd40 a day or to before
#10 superfly_GTR
superfly_GTR
  • 89 posts
  • Car:1970 LC GTR
Posted 27 June 2006 - 10:27 PM
When you do get the old pins out, replace them with VN/VP commodore pins which are very similar to a roll/drive pin, they are a perfect fit and then you can use the pin removal tool as shown in first post, also they are easier to fit, remove and lubricate as they are hollow.
I have them fitted to mine and love them.
Cheers Matt
#11 XUI-86
XUI-86
  • 64 posts
  • Name:Mark
  • Car:LC XU1
Posted 10 December 2013 - 10:02 PM
I made mime, get either one of the steering coupling mounts (column or rack)  from an Lc or Lj. Slot one of the holes to the outer edge and weld a 6 to 8inch bar into the centre where the column/rack shalft would have went. Works a treat.
#12 _jtfenech_
_jtfenech_
Posted 11 December 2013 - 10:18 PM
how are you guys adjusting your doors my pasanger side door is a nightmare to close cause its dropped I was hopping changing the pins might help it lines up fine when its closed
#13 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 13 December 2013 - 02:53 PM
hi john ,is there much movement  when you lift door up and down,a good indication is if you have to lift the door for it to shut,though had a mate thought his was dropped until i pointed out he didnt tighten the the strikers when assembled after painting.
     maz
