Hi guys. It's time to consult my educated Torana brethren on issues of the speedo.
I have used the search with no avail so apologies if this has been remedied before. Someone can drop me the link.
I have a programmable electronic VDO cockpit series speedo with a three wire hall effect sensor on my 700R4 trans. The wiring, sensor and speedo are all new. I have read that the speedo should preform a full sweep when you turn the ignition on.
Here's the first problem. Mine bleeps backward slightly when the ignition is turned on??? There is no full sweep. The digital display comes on showing 0.9 and when i push the program button the trip shows 0.0
Second problem is the speedo has never showed a speed on the gauge. I have tried to perform an auto cal to 1 mile (I live in the states) *Note: I bought the speedo in Australia as a 0-200kph so i'm not sure if it does kilometers AND miles... I didn't try and calibrate in Aus. Anyway the Auto cal came back with error as it does when the pulses are out of spec.
OK throw the suggestions at me.
I have spent hours on this and i'm well pissed with it.
Cheers,
