Hi Guys,
Could anyone explain how to remove the ignition switch from the steering coloum, I have a LX Torana sedan.
It is faulty, as the ignition cuts out if you wiggle the key while the engine is running.
Rob
Posted 09 July 2013 - 07:43 AM
Hi Guys,
Rob
Posted 09 July 2013 - 07:46 AM
Posted 09 July 2013 - 08:19 AM
If its the key barrel, the steering wheel needs to be removed. If it hasn't been removed before the slot where you need to put a flat screwdriver through may still have metal over it.
If its the white slide switch as harna said, drop the colum, it can be adjusted.
