A9X specs
7 replies to this topic
#1 _DINO_
_DINO_
Posted 31 July 2013 - 12:21 PM
Hi guys,
I have a UC Torana hatch, just got back from the engineer and he has asked for specs on an A9X Hatchback Torana rim and tyre sizes, and track widths.
I have no idea where to start so I thought I would talk with like minded Torana  lovers, and see if after 4 years I can finally get my Torry on the road.
I have modified my vehicle and have a cut down 10 bolt out of a WB ute, and HQ front end, with 9" rear American racing rims with 275/40/17 and 7" front with 235/45/17
the engineer won't pass it until he has some specs to go off, so I need some help with this, If anyone has info it would be much appreciated.
Dino
#2 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 31 July 2013 - 09:08 PM
14x6 steel rims with -1/4" (-6mm) offset. Tyres were DR70H14. GMH quoted a diameter of 625mm, the metric equivelant is a 195/70R14. Track was 3" wider than a stock Torana, but i'm not 100% sure on that.
#3 S pack
  • 15,733 posts
Posted 31 July 2013 - 10:03 PM
From Torana Tough by Norm Darwin.
A9X
Front Track 58.5"
Rear Track 57.1"
Tyres DR70H14
#4 _DINO_
_DINO_
Posted 01 August 2013 - 08:23 AM
Thanks guys,
Is there any formal literature that I can present to the engineer. If not I will run with this. I didn't realise engineering would be so difficult.
I will let you know how I go.
#5 Uncle Chop Chop
Uncle Chop Chop
    Grumpy Old Man
  • 1,409 posts
  • Name:John
Posted 02 August 2013 - 09:07 PM
Buy Max Ellorys Torana manual, most of it is in there.
#6 _The Baron_
_The Baron_
Posted 02 August 2013 - 09:58 PM
yes, I am sure there are GMH Bulletins with this info. At the very least CAMS documents.
#7 _outer control_
_outer control_
Posted 03 August 2013 - 03:07 AM
be careful Baron do,nt have an opinion or it will be locked
#8 ls2lxhatch
  • 5,334 posts
Posted 03 August 2013 - 03:25 AM
Thanks guys,
Dr Terry's 60 years of Holden book has the A9X track figures on page 338. His book should be sufficient evidence for engineering.
Front 57.9"   ( 1470 mm)
Rear 56.82" ( 1443 mm )
There is also a L34 service bulletin that lists the track on page 4 as follows.
Front 57.89" (1470.4 mm)
Rear 56.82 (1443.2 mm)
Thanks to Graham we now have this for everyones collection.
L34 bulletin
Edited by ls2lxhatch, 03 August 2013 - 03:31 AM.
