253 power build/stroker help
10 replies to this topic
#1 _Hqstato350_
_Hqstato350_
Posted 20 August 2013 - 06:48 AM
I was wondering if anyone could help me out with a 253 build to get good power I have 5 of them so not upgrading to a 308
I have a few sets of heads pollution and pre pollution tips on porting would be appreciated
All of them will need a bore to some extent that's why I was thinking stroking would be the way to go. I've also got a few 308 cranks
4 barrel manifolds
600 Holley
A few quadrants
Any help would be great
Specs combinations
#2 BIG KEV
BIG KEV
  • 1,218 posts
  • Name:Kevin
Posted 20 August 2013 - 11:44 AM
I don't know about stroker kits for a 253
but I would recommend using a 465 holley as the quady is too big
#3 _ljshawn_
_ljshawn_
Posted 20 August 2013 - 01:23 PM
Build one to the same specs as a Commodore cup 253 I think they make around 400hp
#4 _Bomber Watson_
Posted 20 August 2013 - 03:59 PM
Isnt 308 the same stroke? I know 253 is 3.625" bore and 308 is 4" but not sure on the stroke. Afaik a 355 stroker crank makes a 253 290 or so.
#5 _mumbo_
_mumbo_
Posted 20 August 2013 - 04:14 PM
Yep same stroke but 253 crank is lighter
#6 ReplicarSLR
ReplicarSLR
  • 518 posts
  • Car:Not anymore unfortunately
Posted 20 August 2013 - 06:18 PM
A 308 quady can be ok but this will depend upon cam, manifold and heads etc. If I recall correctly the 253 Commodores came with a quady, but they had different metering rods etc to the 308 version.
#7 Litre8
Litre8
    Thrillseeker
  • 2,399 posts
  • Name:Howard
  • Car:1976 LX SLR8000
Posted 20 August 2013 - 07:41 PM
An old SM article on a 253 buildup.. https://cache.gmh-to...p?sort=3&page=1
#8 _STRAIGHTLINEMICK_
_STRAIGHTLINEMICK_
Posted 20 August 2013 - 08:49 PM
The 253 has similar valve to block problems as the 202 because bore size is the same . so the greatest improvement is by increasing bore size , Call Bob at Action  Crank Service  02 97563840 ,he has done many of these ,and even has a 290 ci engine sitting there which may be for sale .
#9 _Quagmire_
_Quagmire_
Posted 21 August 2013 - 02:58 AM
308 is the same stroke as a 253 so in theory you could bolt a 355 stroked crank and rods in there
piston choice is a separate matter but
or offset grind the crank to fit 350 or 265 hemi rods
i'd keep the quaddie and rejet it...they are a very under rated carb
but to get the best out of them you need to go to someone who knows what thier doing
#10 355LX
355LX
    Long Term Project
  • 611 posts
  • Car:LX hatch
Posted 24 August 2013 - 09:27 AM
Vr-vs 304 block can be had for about $500. Unless you just want something different, why not put all your efforts and money in to something that will make the power much easier?
#11 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 24 August 2013 - 06:11 PM
If you do a search on here there are a few threads on 253 and 308 strokers.
From memory the 305 Chev piston is a good match for the 253 with a 0.120" overbore or similar. You then need to change rods and or the stroke to get deck heights correct. Here are a couple of interesting threads from a while ago....
http://www.gmh-toran...t-out-of-a-253/
http://www.gmh-toran...or-330-stroker/
