can any1 confirm that chev water pumps and crank pulleys are the same bolt pattern as holden v8??
Posted 30 August 2013 - 02:49 PM
Posted 30 August 2013 - 02:51 PM
I know that in HK-HT they are different on the water pump. Not sure about aftermarket stuff.
Posted 30 August 2013 - 02:53 PM
Crank pulley on a 308 is 4 bolt and a Chev is 3....aren't they ?
Posted 30 August 2013 - 03:08 PM
yes from what ive worked out the cranks on chev are 3 bolt not 4 like holden.
mayb the water pump pulleys are the same?
Posted 31 August 2013 - 07:19 AM
Chev water pump pulley is the same bolt pattern as later Holden 6 & V8.
Posted 31 August 2013 - 07:16 PM
Posted 01 September 2013 - 08:21 AM
^ I think he refers to the early 6cly pump which has a smaller PCD.
