253 v8 emissions control
8 replies to this topic
#1 _guvs90_
_guvs90_
Posted 10 September 2013 - 11:19 PM
HI, I'm putting a 253 v8 into my 1974 Lh sedan,
i didn't get any of the charcoal canisters with it, so i was wondering how i can make it meet the emissions control laws
suited to 1977 to make it legal in queensland.
Any help would be greatly appreciated, thanks
#2 dattoman
  • 16,487 posts
Posted 11 September 2013 - 09:05 AM
74 wouldn't have had cannisters
It was pre the ADR's that required it
Same as my LH
Why do you need to meet 1977 laws... is that the year of the 253 your using ?
Who would know unless they are a date code checker ?
#3 yel327
  • 13,682 posts
Posted 11 September 2013 - 09:16 AM
It is a lot of work and expense to upgrade a 1974 LH to 1977 specs especially if it is an auto. You have to change the fuel tank, add vapur separator, vapour line, carbon canister. Then change the whole top end of the engine, add thermo flap into the exhaust plus a fair bit of wiring and plumbing for spark and EGR controls.
#4 TerrA LX
Posted 12 September 2013 - 07:33 AM
IMO stick with the 1974 emissions.
#5 _guvs90_
_guvs90_
Posted 18 September 2013 - 12:44 AM
thanks heaps, didn't realise it was so much work, i guess i could always just try and pull the wool, and just leave it without it........ or would a cat convertor in the exhaust be sufficient?
#6 TerrA LX
Posted 18 September 2013 - 08:57 AM
Cat does not cover all emissions, even commodores with cats have PCV and charcoal canister for fuel tank etc etc...
#7 _guvs90_
_guvs90_
Posted 18 September 2013 - 05:17 PM
is there any way of adapting commodore stuff to work? Or would i be better off trying to find original torana stuff? Or just not worry about it, how would i go explaining it to Queensland transport? inspection officer that it doesn't need it all? I doubt they would believe me.....
#8 dattoman
  • 16,487 posts
Posted 18 September 2013 - 10:13 PM
I doubt they would even notice the age of the engine if you don't tell them
Cannisters are easy to find
#9 yel327
  • 13,682 posts
Posted 19 September 2013 - 07:40 AM
Just stick an aftermarket manifold and a 1974 spec Quaddy on it, they probably won't notice. An Engineer will but not a roadworthy Inspector. Do they look at date codes?
