Rocker covers - standard look vs roller rockers.
14 replies to this topic
#1 _bangbang_
_bangbang_
Posted 13 September 2013 - 11:08 AM
Hello all.
I am currently getting a new engine built for my LX (383 stroker), which will be running yella terra roller rockers. I am hoping to keep the original look of the external engine, which means sticking with the standard rocker covers, however I have been told that the original rocker covers won't clear the roller rockers.
Does anyone have any suggestions how I can overcome this problem please!?!
Many thanks :)
Liam
#2 _Bluejinx202_
_Bluejinx202_
Posted 13 September 2013 - 11:17 AM
I did that with my holden six. If its the same, two rocker cover gaskets works fine
#3 _sbc57lx_
_sbc57lx_
Posted 13 September 2013 - 12:39 PM
YT's fitted under my STD, covers ,  one gasket only
#4 _LHSL308_
_LHSL308_
Posted 13 September 2013 - 02:13 PM
I too had this same problem and was told that the standard rocker covers aren't tall enough when using roller rockers. The other problem with the standard ones or even chrome rocker covers is that they are quite flimsy and can spring oil leaks. I bought a set of these alloy rocker covers which are not only more sturdier in design but are also tall enough to clear roller rockers.
http://www.ebay.com....=item53f6391494
#5 jd lj
jd lj
  • 2,119 posts
  • Name:James D
  • Car:LJ
Posted 13 September 2013 - 07:13 PM
Try Googling "Aussiespeed. Rocker Cover spacers" they make 12 mm alloy spacers for this purpose.
#6 _Mint_
_Mint_
Posted 13 September 2013 - 07:46 PM
i believe the stock type covers will clear roller rockers except for the twist on oil cap tags on the inside..you could modify them(1) to have a push in type cap or breather
someone makes rocker cover spacers for holden v8 but i cant remember who?
you could buy some chrome tall covers and paint them engine colour seen that done before?
if you use the alloy covers(KC type) as Gonedeaf mentioned and you have oversise valve springs and retainers you will have to grind the inside for clearance as i had to
#7 _Mint_
_Mint_
Posted 13 September 2013 - 07:49 PM
thats them
#8 _LHSL308_
_LHSL308_
Posted 13 September 2013 - 08:00 PM
Well there you go, I didnt know you could buy spacers for rocker covers.
#9 _bangbang_
_bangbang_
Posted 10 October 2013 - 09:09 AM
Thanks for the feedback guys :)
#10 dattoman
Posted 10 October 2013 - 10:11 PM
I have rollers with stock covers too
Holden did it... so couldn't see why they wouldn't fit
#11 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 10 October 2013 - 10:23 PM
my girl
yella terra platinum rollers, standard rocker covers
#12 _oldjohnno_
_oldjohnno_
Posted 11 October 2013 - 06:23 AM
That's gonna look great with eight 202 strommies on it :)
#13 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 11 October 2013 - 10:10 AM
nah John, that's why its out,  we replace d the whole thing with a Big Block 202.
#14 _2FLYSLR_
_2FLYSLR_
Posted 23 April 2017 - 07:22 AM
Looks the goods A9X! did you remove the dual IDA's & opt for Quads? Cheers Rick
#15 TK383
TK383
  • 76 posts
  • Name:Tony
  • Car:Blue one
Posted 24 April 2017 - 06:56 PM
The YT rockers usually hit the covers with the adjusting nuts.
Stud type rockers usually fit no probs (ran plenty of crane gold rockers under stock covers).
The Aussiespeed cover spacers don't fit very well & leak, if you have to use them then you'll want to seal the bottom of them with some heavy duty sealant (3bond grey silicon or equivalent) & run thick cork gaskets on the covers.  They are a PITA & it's almost impossible to get a leak free seal using them.
Often 2x thick cork rocker cover gaskets glued together is enough to get clearance, but it does depend on what pedestal height you end up with to get geometry right.
