Should I paint the tubs or put vinyl over them or just put a plate/carpet where the backseat was? no seat unfinished backseat
MINI-TUBBED LC BACKSEAT
gtrboyy
, Dec 05 2005 06:33 PM
6 replies to this topic
Posted 05 December 2005 - 06:33 PM
Posted 05 December 2005 - 07:42 PM
I reckon pad the tubs with vinal covering, and two bucket seats as a rear seat in between the tubs, and what ever gap you have in the middle (in between the buckets) pad that also and vinal it also. Or you could use leather.
This way you dont have to bugger around trying to modify the back seat to make it fit and you have a back seat which looks stylish and practical.
Thats what im thinking of doing down the track, but im a long way off that stage.
_jap-xu1_
Posted 05 December 2005 - 08:42 PM
just vinyl the tubs man.
Posted 05 December 2005 - 09:19 PM
I will probably get them covered in vinyl,but I'd like to see what other people have done though most dont put a backseat in.
Posted 05 December 2005 - 09:47 PM
yeah i recon go matching vinyl.
Posted 24 December 2005 - 08:37 PM
Hi,
Id carpet the whole back area if your running no seat. The metal work on the back wall is pretty ugly. Or just mod the wires in your seat to fit the tubs even if you dont plan on using them. Not to hard.
Adam
Adam
Posted 02 January 2006 - 09:25 AM
hey chief,
i'd probably vinyl the tubs. although the difference between the new and old vinyl would be slightly noticeable, you would be hard pressed to get carpet to sit in neatly against the tub, even if you got a professional to heat it into shape. the vinyl would look factory, yessir it would.
