Rear trailing arms?
18 replies to this topic
#1 _Dustings_
_Dustings_
Posted 16 October 2013 - 08:50 AM
Father wants to know if HQ & Torana rear trailing arms are the same?
#2 A9X
A9X
    A fortunate run
  • 5,024 posts
  • Name:Welby
Posted 16 October 2013 - 10:32 AM
no they are not
#3 _Lazarus_
_Lazarus_
Posted 16 October 2013 - 11:41 AM
But are they interchangeable ?
#4 ls2lxhatch
  • 5,334 posts
Posted 16 October 2013 - 11:43 AM
From memory the HQ rear lower trailing arms are longer than the Torana.
#5 _Dustings_
_Dustings_
Posted 16 October 2013 - 07:58 PM
Thanks for your help guys
#6 _Lazarus_
_Lazarus_
Posted 17 October 2013 - 07:03 PM
I was under the impression that they were interchangeable so got the tape measure out this arvo and had a look.
The Torana ones are longer actually, by approx. 100mm.
Couldn't be bothered checking the tops as the HZ is pretty low but I'm pretty sure they are the same ?
#7 WhiteA9XS
WhiteA9XS
  • 1,646 posts
  • Name:Shaun
  • Car:LJ LX
Posted 17 October 2013 - 07:47 PM
is the old man looking for more pinion angle timmy ?
#8 _Dustings_
_Dustings_
Posted 17 October 2013 - 07:49 PM
No idea Shaun, I just did what I was told :)
#9 WhiteA9XS
WhiteA9XS
  • 1,646 posts
  • Name:Shaun
  • Car:LJ LX
Posted 17 October 2013 - 08:15 PM
no probs tim , looks like the q ones wont fit , 100mm is a big difference
#10 _Bomber Watson_
Posted 17 October 2013 - 08:16 PM
THat will drastically change the pinion angle though....
#11 WhiteA9XS
WhiteA9XS
  • 1,646 posts
  • Name:Shaun
  • Car:LJ LX
Posted 17 October 2013 - 09:48 PM
and make a mess of the uni joints and shaft
#12 ls2lxhatch
  • 5,334 posts
Posted 17 October 2013 - 09:59 PM
There is not much chance of the wheel fitting in the wheel arch with lower arms 100 mm shorter.
#13 _Bomber Watson_
Posted 17 October 2013 - 10:23 PM
Pfft LC/LJ wouldnt be much worse off lol.
#14 _Lazarus_
_Lazarus_
Posted 17 October 2013 - 11:39 PM
I had some Toyota Crown ones around here somewhere. I had a bit of a look for them this arvo, will try harder tomorrow. They are fairly long if I remember rightly.
#15 Dave6179
Dave6179
  • 577 posts
  • Name:David
  • Car:HJ, VN, VX SS
Posted 18 October 2013 - 08:17 AM
Good boy, way to stay on the will. :spoton:
I just measured an HQ arm with good bushes (centered) 558mm.
Edited by Dave6179, 18 October 2013 - 08:20 AM.
#16 ls2lxhatch
  • 5,334 posts
Posted 18 October 2013 - 11:05 AM
The LX Torana trailing arms are 657 mm to the centres.
#17 _330OLX_
_330OLX_
Posted 18 October 2013 - 06:42 PM
The top ones are the same though
#18 _Lazarus_
_Lazarus_
Posted 18 October 2013 - 07:29 PM
Sorry, can't find the Crown ones. I've either thrown them out or they're in the back of my old Crown wagon over at my mates place.
But looking at the chassis specs in the manual I'd say they are around the same as HQ - WB as it is 528mm from front LCA mount to axle centreline.
#19 _Lazarus_
_Lazarus_
Posted 19 October 2013 - 08:55 AM
ps. The Crown ones might be worth investigating for a lowered HQ - WB.
The width and basic design is very similar.
Just checked, both 60mm space in diff bracket.
The Crown rear mounting point is not far back from the centreline so total length maybe 540 - 550mm ?
