Engine Dies!! 350Holley/CainManifold Related
#1 _JBird_
Posted 03 July 2006 - 04:06 PM
It has been sitting at the panel beaters for about 3 months, I got it back a few days ago. I drove it home from there (about 2 minutes drive). Today I tried to start it again to go get a blue slip. Battery is fine. The fuel bowl vent started spurting fuel upwards (like a geyser) a little while after my engine started. It runs for about 10seconds before it shudders and dies. gtrboy (Shane) came around to have a look and we adjusted the fuel level to be at the right level. Seemed to do nothing. Tried to figure out whats wrong but to no avail. He reckons because its been sitting still for too long somethings stuck inside.
Basically my car can't idle if I keep revving it on start up (constant 1750rpm) itll stay alive, dropping it below that it starts spurting fuel upwards.
Any help/diagrams/rants would be appreciated. (Thanks Shane for comin round )
-James
#2 _torana_
Posted 03 July 2006 - 05:34 PM
cheers julian
#3 _munro_
Posted 03 July 2006 - 06:13 PM
#4 _Yella SLuR_
Posted 03 July 2006 - 06:47 PM
Posted 03 July 2006 - 06:58 PM
#6 _Pete_
Posted 03 July 2006 - 08:13 PM
#7 _JBird_
Posted 03 July 2006 - 10:26 PM
Posted 03 July 2006 - 10:33 PM
#9 _JBird_
Posted 03 July 2006 - 10:46 PM
Well remove the fuel bowl and check it out.
#10 _Herne_
Posted 03 July 2006 - 10:52 PM
#11 _JBird_
Posted 03 July 2006 - 10:55 PM
Edited by JBird, 03 July 2006 - 10:56 PM.
Posted 03 July 2006 - 10:56 PM
holley.com might have other pages you need aswell.
http://www.holley.co...ice/Library.asp
Edited by ALX76, 03 July 2006 - 10:57 PM.
#13 _JBird_
Posted 03 July 2006 - 11:05 PM
Posted 03 July 2006 - 11:36 PM
#15 _wombat_
Posted 04 July 2006 - 01:39 AM
Posted 04 July 2006 - 01:41 AM
are u seriousunleaded fuel tends to go off after 5 or 6 weeks and turn into a gummy sludge that will block up jets and all sorts of things.
#17 _wombat_
Posted 04 July 2006 - 05:26 AM
#18 _wombat_
Posted 04 July 2006 - 05:29 AM
Edited by wombat, 04 July 2006 - 05:30 AM.
Posted 04 July 2006 - 10:18 AM
The needle & seat usually sticks open, allowing the float bowl to flood, this is very common on Holleys.
Dr Terry
Posted 04 July 2006 - 10:22 AM
Your point on E10 & ethanol mixes, you said "thats why dray racers that use it straight drain fuel system and run engines dry to stop injectors blocking with the crap. "
I know it's a typo & you meant drag racers, but drag racers do not use ethanol, they use METHANOL, a very distant relative. Ethanol is actually metholated spirits, a by-product of the sugar industry & a good cheap renewable fuel that burns clean & for the last 4 years has had much bad press for no known reason. Common sense is now prevailing & its use is more common, with E10 now being recommended by the Australian auto makers, much to the disappointment of the petrol companies. METHANOL on the other hand is highly corrosive & cannot be left in carbies or fuel tanks for any length of time, which is why it's drained & flushed after races in drag cars etc.
Although we do have problems with unleaded fuels as far as evaporation goes, this was much worse with LRP, which is no longer sold. I think the problem in lawn mowers is that they are left for long periods & many probably still have remnants of LRP in them.
Dr Terry.
#21 _bones_
Posted 04 July 2006 - 12:35 PM
Good luck,
Bones
#22
Posted 04 July 2006 - 03:09 PM
Due to my car sitting for long lengths of time and not being run, THe fuel evaporates out of the bowls and leaves a residue.
The first was a white poweder left from optimax fuel. THe powder was all though the carby and took 2 days of "acid" bathing to remove mostly,
The second was a dark brownish gummy material that was from mobil 8000.
I now use BP ultimate and have had little or no trouble, but i also still use Mobil if needed.
Defintiely sounds like a needle and seat, You can buy replacements very easily and by removing the screw and nut assembly off the top of the bowl you can then replace teh whole needle and seat assembly!
Good luck!
#23 _JBird_
Posted 04 July 2006 - 04:27 PM
Shane came over today and the needle and seat was taken out (several times) and put back in, drove around trying to find a new gasket for it because it started leaking once my engine got fired back up. Well it runs perfect now after a bit of adjusting to get the levels just right.
Mustve gotten gunked up I suppose. Serves me right for not driving it enough ... lol
Big thanks to Shane for wasting his day off
I drove it down to the blue slip place and I "only" have to get my demister to work (possibly just use hairdryers), get the blinker canceller thingy to work and last but not least make sure the key doesnt come out of the ignition barrel after its been turned on.
-James
#24 _Pete_
Posted 04 July 2006 - 10:09 PM
#25
Posted 04 July 2006 - 10:27 PM
yes, it is actually a defect to have the key removed whilst not in the lock position.Every early holden i've owned has an ignition barrel that allows the key to be removed while the car is on..........I always thought it was just a Holden design flaw, whats the fix a new key or barrel etc??
