Calling on 186/235 stroker owners
22 replies to this topic
#1 looznugtr
looznugtr
  • 528 posts
  • Name:Matthew
  • Car:2/70 LC gtr 2600s
Posted 30 November 2013 - 07:47 PM
Hi I am looking into doing a stroker motor.
I have a 173 block that has been sonic tested.
Came with all machining done for a stroker and ford 3.9 pistons.
I need a crank and I am onto a kit cullen 1 piece counter-weighted crank.
I am told they don't like "REVS" but this is not a problem.
The plan is to make as much HP/Torque up to around 5500 which is the rev limiter i had on my old turbo 202 setup. 330 HP.
What input can you stroker owners let me in on.
Thanks Matt
#2 _Dansthemanow_
_Dansthemanow_
Posted 01 December 2013 - 12:27 PM
Well you might get close to 300hp with a rrv limit of 5500.prob a bit less.Being a stroker,its inherently unsuitable for high revs anyway.6500 would be a realistic limit to retain good reliability.5500 wont even work up a sweat.
Maybe a custon grind cam specific to the stroker
would be ideal,but off the shelf grinds for the regular sixes can give excellent results.You might try adjustble timing gears as advancing the timing will work a little better on the stroked motor.Due to the bigger cubes.you need to remember advertised power bands will fall by maybe 1000 rpm when installed in the stroker.You really need 50 thou duration of around 240 - 250 degrees to make good power at 5500.The old waggot 104 seems to work great,but im not sure if u can still get them off the shelf.Otherwise try camtech.Personally never been impressed with crow cams.Also u can run 1.6 rockers without incurring a lot of stress.due to the lower revs of the stroker.You will not need quite as much spring pressure as you would in an un stroked motor.
Basically the head is always the limiting factor with the power,so you need a good porter,unless you run a j zed head which flows well out the box.
Both the 9 and 12 port can give similar flow,but the 12 port should give more torque,and is probably preferable if you run webers or dellortos.If your just gonna run a holley,a 9 port will work just as well and is maybe less prone to cracking?Of course theres the 12 port alloy which saves you 20kg and will potentially flow a little better than factory castings.
And you should maybe run a bigger damper on the crank.A main girdle doesnt hurt.Not sure how they fit with the stroked crank?
Maybe consider custom headers.as the off the shelf ones are all 1.5 primaries.You might pick up a bit with 1 5/8 primaries,but its a fair bit of expense to get them made.2 1/2 in collector is beneficial once you get up around 300hp,2 1/4 is starting to restrict flow at that level.
#3 _Skapinad_
_Skapinad_
Posted 01 December 2013 - 01:06 PM
http://oldjohnno.id.au
#4 Hell34
Hell34
  • 37 posts
  • Name:Peter
  • Car:LH ,UC ,HQ GTS 350, 94 Camaro 648 ci
Posted 01 December 2013 - 03:09 PM
I have spin mine to 8000 rpm with out any problems for over 20000 Km just need good cam and head work
#5 _Bomber Watson_
Posted 01 December 2013 - 03:42 PM
Really, an alloy head saves 20kg Dan?
An iron head weighs 26kg with valves, springs collets retainers etc, everything bar the rocker gear.
What does a complete alloy head weigh? For some reason i doubt 6kg?
#6 _STRAIGHTLINEMICK_
_STRAIGHTLINEMICK_
Posted 01 December 2013 - 06:00 PM
Ive sent alloy heads in the post and they weigh 16kg complete with packaging ,
#7 _Bomber Watson_
Posted 01 December 2013 - 06:02 PM
THAT, i would believe.
#8 limo
limo
  • 2,673 posts
Posted 01 December 2013 - 07:24 PM
dumb question maybe but why use a 173 block? Can it be bored to same as 186 or 202?
#9 _Bomber Watson_
Posted 01 December 2013 - 08:16 PM
Not if its a red.
#10 _Skapinad_
_Skapinad_
Posted 01 December 2013 - 08:18 PM
Blue though yeah ?
#11 looznugtr
looznugtr
  • 528 posts
  • Name:Matthew
Posted 01 December 2013 - 08:33 PM
NO it's a 173 red and it's how i got it. OD prefix
Has been sonic tested so i can only assume it's good.
Was build for a turbo project and block was chosen for its think walls.
It is 91.86mm which is smaller than stock 186 and 202.
Something tells me this block was chosen as it had a larger core....(HP 179x 186 and 202 all have the same core)
Why cant a 173 have the large core as well.
Im just wondering what lets go if you oferrev strokers?
Rods?
Crank?
Pistons?
Block?
Why would a 9 port be less prone to cracking?
#12 _Bomber Watson_
Posted 01 December 2013 - 08:34 PM
Blue though yeah ?
Some.
#13 Steve TPF
Steve TPF
  • 784 posts
  • Name:Steve
  • Location:Adelaide... city of... anyone know something good about it?
  • Car:UC hatch
Posted 03 December 2013 - 05:02 PM
There was recently a lengthy discussion on strokers here: http://www.gmh-toran...troker-6-crank/
Might answer some of your questions.
#14 _Dansthemanow_
_Dansthemanow_
Posted 03 December 2013 - 08:02 PM
As for the heads cracking,i havnt cracked either type.Ive been told the 12 port heads were prone to cracking,and that is supposedly why yella terra made new cast iron replacements at one time.
In any event,yella terra say the alloy is 60% lighter than stock,which would equate to 15 kg less,if the stock is 26kg.I never weighed either,but aluminium is half the weight of iron so lets just say there is a worthwhile weight saving.
As far as what is prone to break at high rpm in a stroker,the same parts as in a non stroked motor.You need to consider the extra stroke plus the reduced rod length/stroke ratio means at 5500 rpm,your piston changes direction at TDC at the same rate as a 179 would at 6500 or 7000rpm.At 8000 rpm,you stroker rods and pistons are experiencing exactly what they would at close to 10 000 rpm if they were in the 179.
I can tell you your gonna reach your limit of power in a 234 engine by about 6500 rpm.Maybe it hangs together until 8000,but above 6500 the power will be falling.Mine made peak power at 5800,and thats with a head flowing 307hp and tripple 45 dcoe intake.If it hangs together at 8000 with carillo rods and forged pistons,good luck.but a holden head will run out off puff well before that point in a 234.But in any event the OP said he wanted to limit rpm to 5500,starfire rods and cast pistons like ACL race series will be just fine at those revs.
#15 _Bomber Watson_
Posted 03 December 2013 - 08:40 PM
I agree with the last comment.
The 26kg was with valves springs collets retainers etch which all have weight and are the same alloy/iron....
I can weigh a bare head if you wish?
#16 looznugtr
looznugtr
  • 528 posts
  • Name:Matthew
Posted 03 December 2013 - 08:49 PM
What was the stroke a prostroke crank made?
#17 _Dansthemanow_
_Dansthemanow_
Posted 03 December 2013 - 10:56 PM
The prostroke crank i used was made from a factory ford and holden crank joined together.Both cranks are forged steel from factory.It was nitrided also.
A billet 4340 crank is gonna be tougher than the prostroke,but either would be bulletproof at 5500rpm I would say.
I dont even think prostroke do them any more on account of ford 221 cranks being very hard to find nowadays.
#18 _Dansthemanow_
_Dansthemanow_
Posted 03 December 2013 - 11:00 PM
Oh.The stroke of the prostroke crank was 3.68 in. I think.
#19 _Dansthemanow_
_Dansthemanow_
Posted 04 December 2013 - 12:17 AM
#20 _Dansthemanow_
_Dansthemanow_
Posted 04 December 2013 - 12:33 AM
You made your point.You can use bathroom scales and i cant.Sorry.
#21 _tryhard_
_tryhard_
Posted 06 December 2013 - 05:53 PM
Hi dan if you need help with your stroker or turbo stroker pm me I,ve done both and are in the process of doing a 2.8 / 173 blue block at the moment
Sorry Dan I ment that last message for Mathew
#22 _Dansthemanow_
_Dansthemanow_
Posted 22 July 2016 - 03:36 PM
actually i just put a complete 12 port iron head minus rockers on the scales.29kg was the reading.Y.T claim the complete head is 60% lighter than factory, believable given that al alloy is bit over a third of the weight of iron.Still a good weight saving given that its all sitting up high and over the front wheels.
Edited by Dansthemanow, 22 July 2016 - 03:42 PM.
#23 _Skapinad_
_Skapinad_
Posted 22 July 2016 - 05:16 PM
Geez, delayed reply ;)
